Question about Refrigerators
How to remove the spinle blades from washing machine
We have an "energy saver" top loading washing machine with a belt and buckle caught under the spindle. how do i remove the spindle blades please?
  • 2 more comments
  • ken macgowan Dec 12, 2009
    i now realise it is called the agitator. It is an old top loading model and on the plate it has HWA8067FW819 and then DC 587599. I want to remove the agitator. I took off the cap and there was the top of a central pin with a grooved depression in it. I could not see a bolt. I cant get my fingers under the agitator as there is not enough room, and the agitator blades and shaft taper all the way to the top. do i just keep on pulling, or is there some sort of allen key to go into the top of the metal shaft that has to be undone first?
    general electric, but only sign of a model name is 'energy saver' plaque on it
  • steve
    steve May 11, 2010
    We must have a model number to help you.
  • dennis dodge May 11, 2010
    need brand and model # then i can give you what you need. mm
    President:
  • 1,891 Answers
You did good with the brand . if it's older model there is a spline at the top agit . and if its a newer style the drive is at the bottom . ineither case it just pulls of . but they do stick . I use a agi-tamer ( brand name . it is a flat type heavy rubber round tube with a split in it slide it under agit add water and it will raise it up .. hopt this will help mm
Posted on Dec 12, 2009
How do I remove clothes from under agitator?
Believe it or not the agitator will come off. Look under the fabric softener cup. There should be a fastener (nut or bolt) to loosten. Give the cup a good cleaning while you have it off.
Once the nut is removed you can work the agitator off.
Jul 27, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
GE Profile WPRE6100G Top Load Washer how do you bypass lid safety switch? Unit pumps but won't spin.
worst washer I ever owned how do you bypass water level so you can wash a comforter man I am so disappointed with this GE Profile energy saver if I can't move the water level up I'm going to put it out along the road a trash day and it's only 4 months old
Dec 19, 2010 | GE Profile WPRE6100G Top Load Washer
Roaring sound on washing machine when spinning
Hi, It's more likely something caught in the pump or bad pump. Remove the belt under the machine and check the pump pulley for noise.
Apr 08, 2010 | Maytag MAV7600 Top Load Washer
Kenmore 80 series washer is it energy efficient
yes
and
yes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 06, 2010 | Kenmore 24032\24036 Top Load Washer
How do i fit a belt to hotpoint washing machine WF865
*********** unplug from mains************** top cover off ....rear cover off ....remove old belt belt ...place new belt on lower puly feed it on to larg pull turn at same time ************WATCH YOUR FINGERS ********THEY CAN GET CAUGHT EASY******* done .put covers back on ...
Dec 30, 2009 | Hotpoint Ultima WF865 Front Load Washer
Won't spin or drain water
Something may be caught in fan that cools te motor. Tilt unit back and look for white fan blades. Is somjething caught in it? /
Sep 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing machine won''t drain
HI thanks for your questionOn your washer theres a electric pump sometimes foreign objects get caught in pump remove front panel . Using a blade screwdriver insert between top & front panel about 2 inches from corner .The front should now come off .The pump is on the left side . Disconnect pomer If your washer is full of water now put drain hose on floor or in bucket to drain water . Now remove hoses from pump & clean reinstal . Thanks for your question The appliance doc
Sep 06, 2008 | GE WHRE5260E Top Load Washer
Ge washing machine removing side to look at inside
should be 2 clips under the front of the machine, just below the top. they should be able to be pushed slightly in to release from the front panel
Jun 19, 2008 | GE WBSR3140DW Top Load Washer
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
