Question about Refrigerators
Ars266bw-coil is freezing solid-elenent checks good- when timer is advanced to defrost-voltage is there but no heat
    President:
  • 1,214 Answers
Are you certain the defrost elements are good? You should be able to check for voltage at the same points that you checked for continuity. No voltage, then look upstream toward the defrost control. Voltage - then look to downstream to the defrost heaters.
Posted on Dec 12, 2009
Whirlpool refrigerator freezes,but not cold enough in lower part. I performed the steps to determine if its a faulty timer,defrost resistance or thermostat.If the refrigerator cycles on and off normaly,but...
Yes by advancing the defrost timer to the defrost mode and the heater not come on the defrost timer is good and it will be either the defrost heater or t-stat
When checking the defrost heater using a multimeter set to measure ohms of resistiance the defrost heater should measure to be appx 10-20 ohms if good and infinate ohms if the heater is defective
If good the defrost thermostat will be ZERO ohms...please note when checking the t-stat it MUST BE CHECKED WHEN COLD so its best to check it when frost is built up on the evaperator (freezer)coil
GENE
Oct 14, 2011 | Refrigerators
It's freezing everything.
Hi, refrigerators have either a mechanical defrost timer, or an ADC (Adaptive Defrost Control). If your refrigerator has a mechanical timer, set the cold control to the coldest setting and then advance the defrost timer. You can manually advance the timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8's of a turn. If the compressor starts, replace the defrost timer. For further help, you'll want to call a professional appliance repair technician.
You can use a condenser coil brush to clean the coils periodically. Because the coils exchange heat, any dust, lint, or dirt on them cuts down its ability to exchange heat.
May 19, 2011 | Dometic Refrigerators
Hotpointt FFA80 freezer door kept opening on its own. noted that ice had formed and was pushing drawers against door. cover removed from coils and found solid with ice. left to defrost but when plugged...
Does the light inside the fridge come on? if it does then you are getting power. If not you are not getting primary voltage. As far as resets or cut outs there is three things that can stop the power to the compressor 1 the cold control (thermostat you set to raise or lower temp) 2 defrost control that is suppose to cycle and put the fridge into the defrost cycle about one time every 24 hours. 3 the over load heat activated cut off that is a small round device usually on the side of the compressor (the big black round can that is in the bottom of the fridge) Since ice formed I would check the defrost control first. It is a timer that should advance slowly on its own but usually can be turned by hand to advance to the defrost position. the defrost timer is usually at the bottom of the fridge and many times can be seen from the front of the fridge when the "kick plate" or bottom grate is removed. if you can find the little knob on the defrost timer try to turn it to the right (clock wise) and see if anything changes. Since the ice formed either the heat element that defrosts the coils or the defrost control has probably stopped working.
Apr 22, 2011 | Refrigerators
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My ge side by side will freeze up the coils in about seven days. service tech came out and replaced a heating coil inside of the unit and we are still expieriencing the same problem. the compressor pulls...
Since the heater has been replaced, you could have a bad thermodisk, but more likely a problem with the defrost timer. The tech should have checked the heater and disk rather than replacing the heater blindly.
You probably know some of this but for me it's a copy-n-paste.
All frost-free refrigerator-freezers with exception for the ones with solid-state control have a thing in the system called a Defrost Timer. The thing is a little clock of sorts that tracks accumulated running time. Every 8 hours of run time the thing cycles through a defrost cycle. The defrost cycle is necessitated by the humidity that forms ice crystals on the freezing coils, if the frost is not eradicated it can build up to the point where no air flows over the coils to chill the inside of the box. (it may keep the freezer cold but no air goes to the fridge part. If completely solid neither cools) Most timers are located on the front of the machine, behind that removable grille under the door. Sometimes it's found in the refrigerator behind a plastic cover. The timer has a round hollow shaft through it, and can be turned with a screwdriver. If the compressor is running, give the shaft a slow twist until a click is heard. The compressor will stop. Give the fridge an hour to defrost the coils, and check it to see if it took off running. If an hour has passed and the fridge hasn't restarted, advance the timer again to start. Sometimes the nudge will make the timer run for a while. If this is the case, the unit will chill, and buy you some time to get it fixed. If the timer does not run, you can repeat the process daily until you get a replacement timer.
Hope this is helpful for you.
Jul 13, 2009 | GE GSL25JFR Brushed Steel Side by Side...
GE side by side GSS20IEP Refrigerator freezer freezing
this is a problem that is no stranger to most GE side by sides; GE has used a glass type defrost heater in the freezer which often fails. If you manually defrost your appliance (unplug and leave doors open for 24 hrs) then plug back in, it will appear to work normally for a few days and gradually build up frost on the evap panel (back panel in the freezer) and eventually the refrigerator side will seem to loose cooling due to frosted damper, or lack of cold air transfer over the evap coil. The fix for this is to replace the defrost heaters (s). While not as common, defrost thermostats can open causing the unit to skip defrost, and even less likely is the defrost control (either mechanical timer or adaptive defrost). First, defrost your appliance, then remove the evap panel and ohm out the heater(s), if open, replace. If they check ok, check your defrost thermostat (small disc like object attached by a clip on the evap. coil itself) for signs of popping open or open ohm readings at normally closed temperatures. Its a good idea to change this anyway when replacing defrost heaters as the two work hand in hand. Last, check the defrost timer by manually advancing the screw advance clockwise until you hear the first click, then check voltage to the defrost heater and thermostat, if no voltage present replace timer. If your appliance is equipped with a adaptive defrost board, refer to the schematic for proper diagnostics.
Jun 11, 2009 | GE GSS20IEP Side by Side Refrigerator
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
