Question about Gateway GT5656 Desktop PC
My PC has started to shut off without warning. I could be playing left for dead or sometimes just normal browsing, or even sitting idle. I Changed PSUs and Reformatted and reinstalled Vista and it just happened again. I believe I have some faulty hardware, maybe video card? or memory. I know that you can test memory using such as memtest86 but I put that on a cd and it would never boot to the test. Is there a way to test other components? Videocard or other motherboard components? Perhaps my CPU is overheating? I measured my core temp after the shutdown and my cps cores were at 59C/54C. Its a gateway gt5656 other than Video card it is stock. Video card is EVGA 8600gt 256mb. Any help is appreciated.
  • genjizero Dec 12, 2009
    I have since removed my video card and enabled onboard video and still have had it shut off...
    I dont understand how the oboot disk works, Ive extracted the files to a cd and rebooted and it still boots to vista. As for the Heavyload program, if it causes the PC to shut down, Ill lose the data wont I? how will I know what component caused the shutdown?
    Sniper:
  • 65 Answers
The first thing i would try is hiren's boot cd. Here is a link to the free software. On it you will find a memory test and a hard drive test.
http://www.hiren.info/pages/bootablecd
you may also want to try testing your video card and onboard video with heavy load here is a link to that software as well. This is a stress test that will push your pc to its limits. should help you identify the issue if memoery and hdd pass.
http://www.jam-software.com/freeware/index.shtml
Posted on Dec 12, 2009
  • Alexander Slocum Dec 28, 2009
    you have to unpack the cd then compile it as an iso. Lot's of freeware available to do this. such as iso buster (free trial) then after you create the image burn it to a disc using image burn then boot to the cd before windows starts. If you are sill having issues using on board then you know its either a powersupply issue, memory stick. hard drive, motherboard, or software corruption.
"Warning Lights" on the dashboard of "1995 Nissan Maxima"
The warning lights coming on with the key in the on position is normal. If the key is turned to the start position and the engine will not crank over, suspect an internal starter motor problem or lack of power to the starter solenoid. You can try tapping on the starter motor with a blunt object while someone holds the key in the crank position to see if it starts when this problem occurs. If it starts using this procedure, the starter motor will be defective
Feb 20, 2016 | 1995 Nissan Maxima
Tip
How to browse without antivirus and keep your computer safe
after browsing or even inserting an infected drive to your pc, do not shut down the system normally like clicking on start and clicking on shut down all you need do is just to hold down the on/off button till the pc offs.
the reason is that if you shut down normally, the system will save the current settings and some viruses will go and embed with some system file and this can affect the system.
on Jun 13, 2010 | Computers & Internet
High idle
What control idle is RPM sensor[TPS] to check it is OK.
Jan 28, 2013 | 1999 Pontiac Grand Prix
Kia Rio cutting off
im assuming that changed the oil unit you mean sending unit ? if so could be electric short in the pick tail or worse wiring harness. second there is also possoble vacum leak .third while unit was being replaced something didnt get put back or got knocked loose. created a new problem. most times as thing are going bad they dont register until it is a prolonged problem as it took 2 days for the check engine to go out that also might have been normal. you might also notice while sitting at park when you turn the wheel you will notice ia differance in the idle, if its almost stalling then its probley your idle,needs re set, or your idle controle valve is going bad ,did it get checked or cleaned when they serviced the throttle body. and also could be your mass air flow sensor going bad or need cleaned
Jul 08, 2010 | 2003 Kia Rio
99 dodge durango keeps shuttin down every so often cleaned battery cables and replaced clamps on both terminals worked for a day then same thing and security light will come on if i unhook pos cable and...
2002 Durango shuts down without warning. Sit for about 30-45 min and will restart, run for a while, and shut down again. Shows "NO BUS" code. Took it to Dodge Dealer and had a diagnostic done....nothing!!! Have changed PCM, crank shaft sensor and am getting ready to RUN IT OFF A CLIFF if I can get it running long enough!!! It is a black hole and we are getting no where!! I can't even sell the dang thing!!
Aug 14, 2009 | 1999 Dodge Durango
Dell Laptop shuts off
Take out the battery and only hook up the AC Adapter to the laptop. See if it still shuts off on you at random.
If it still does then try another AC Adapter and if it still shuts down randomly then it might be a motherboard issue.
Take a can of air and blow it into the air vents on your laptop. This will remove any dust or debris that might be affecting air flow.
If that doesn't do it then the only other thing to try would be to take apart the laptop and where the heatsink sits on top of the CPU, take the heatsink off and make sure there is no dirt or dust buildup on it. If there is buildup on there that would cause the laptop to shut down without warning cause that means its not cooling like normal.
At this point if you went thru all of this and you still get shutdowns then the motherboard is bad
Aug 08, 2009 | Dell Computers & Internet
Is it really dying?
It's possible the battery is dead, but the phone may also be too full of old files/msgs/pics/applications/games etc... the phone needs a certain amount of memory to function.
Try another battery or a new one, if it starts do an update of the phone software (firmware). You can do this yourself, but it may be better left to a repair/sales shop.
You need to download the latest Samsung PC Studio to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
“I can resist anything but temptation.”
Apr 25, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Un-initiated shut down
it cud be issue with RAM/graphics card as you mentioned that you were online gamimg.when the pc cannot handle the request it becoms unstable and just shuts down.
Feb 11, 2008 | Sony VAIO PCV-W10 PC Desktop
Gateway GT5656 Desktop PC Logo
186 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
