Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Thanks for the information - is it hard to change a compressor relay or will i need a professional ...
  • Kenmore Master
  • 4,655 Answers
That should be easy unplug from wall and remove cover from the side of compressor, mark wires and replace with one that that model call for. It is not always the start relay that causes the start relay to go bad. So if you know it is the relay I will walk you through this.You can find me here at Fixya or=> Here or here=> Sea Breeze Appliance Parts and Technical Services if you need answers let me know! Hope that helps you, Thanks, Sea Breeze
Posted on Dec 12, 2009
  • John Tripp
    John Tripp Dec 12, 2009
    Oh please find your Kenmore model number before we chat. The number will be most likely near floor on bottom of fresh food section door or in photos below,
Compressor hard to start.
as in previous answer a minute ago. AMP the compressor and check your pressures. you need to call a professional, because you obviously are grasping at straws and know little of this device.
call a professional.
Dec 30, 2014 | Refrigerators
Neither compartment hasnt worked in 2 day fan is on continusly. cleaned coils of dust now in hearing a clicking ever 2 minutes could it be low anti freeze
This means the relay to the compressor failed to run the compressor, so check the relay and replace if needed. if with a new relay the compressor doesn't run than the compressor could be lock and would need to be checked or replaced. Its really hard to give you more information without a model number are not every model works the same anymore. I hope this leads you in a quick resolution of your issue. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 16, 2014 | Refrigerators
My refrid is on but compressor clicks off and on
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Refrigerators
Compressor is not getting on but fan is working fine and i noticed the fan out air is not hot
If the compressor is not working then for sure your AC is not working. So first of all we need to check why the comrpessor is not switched on. Need to check on the thermostat if the relay is activating according to the set data.
If so the comrpessor relay must work or both compressor and relay can be faulty. Check also the capacitor to the motor.
The main controller must give the output to trigger relay, Can be bypassed to confirm status of compressor /relay/capacitor or else the main controller board can be faulty.
Sep 11, 2010 | Samsung AS18A6RB Air Conditioner
The compressor will not kick in It will start up and try but will not run Fan continues to operate Almost sounds like the compressor motor is binding trys for about 2-3 seconds and shuts off fan will...
The condition you describe usually indicates that either the compressor is working too hard and drawing too much current or the start relay is gone bad. The noises that you hear may just be a safety shut-off within the relay. A good place to start is changing start relay for the factory recommended one. you will have to access the compressor compartment to see this.
If the standard relay does not correct the problem, there is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your dehumidifier first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system or a faulty compressor. Outside of this may require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a refrigerant leak.
Check your owners manual before making any repairs or modifications to your refrigerator. And there may be an extended warranty on the sealed system and compressor if needed.
Aug 06, 2008 | Maytag M7DH45B2A Dehumidifier
Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Aug 01, 2008 | Kenmore 53642 / 53644 Side by Side...
With engine running a/c compressor engages with the a/c unit off.next day when i turn a/c on the compressor does not engage.if i ground the relay it works, but when i turn the a/c off in the car the...
HI,
The airconditioner turns on the auxillary fan when the compressor is on via a relay. I would change the relay. If hard wired the fan to the compressor I would think the fuse has blown since there is too much of a load on one circuit. Check to A/C fuse. If the fuse is no good replace it.If it is not the fuse, check the fuse under the HOOD..
Please post back for how things turned or for further assistance..Thank you!..Regards!!..
Jul 19, 2008 | Nissan 240SX Cars & Trucks
Kenmore model 105.53534300 side by side refridgerator not cooling
Relays are located on the left side of the compressor. How long ago did you smell the burning smell? Are you 100% sure the compressor is running? If it is, nothing is wrong with the relays. Although sometimes it is hard to tell if the compressor is running. By morning temps will be higher than tonight if compressor isnt running. If it isnt running, relays must be changed. I will post shortly on how to change the relays.
Dec 23, 2007 | Kenmore 53542 / 53544 Side by Side...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
