Question about Olympus FE-330 Digital Camera
Olympu fe-370 digital camera-won't turn on when push power button
Battery is relatively new and charged--no reaction when i press the power button
  • 691 Answers
Hello
Thank you for using FixYa for your problem
Always check the batteries first - try a different set too but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Dec 12, 2009
My camera won't turn on even though it's fully charged
Is there no sign of any light from the camera when you turn it on? When was the last time you used that camera? If you have left the battery inside the camera for quite some time, then most probably, it got exhausted. Despite of being charged for hours, can you put back to the charger again and see if it gives a red battery charging indicator? If it gives a red light, then you may need to replace the battery pack.
Hope this helps. Thank you for using FixYa.
Dec 20, 2010 | Olympus FE-370 Digital Camera
When I push the power button the lense moves in and out several times then the camera just turns off. I tried charging the battery and holding the power button down for 10 sec. but still does the same...
The power button has two purposes explanable;
1. A firm press and hold would shut down the entire device, where would be common feature for the camera to perform a system check to include the lense functionalilty.
2. A gentle press and release of the same power button should capture a snap shot only after the camera has been powered on, by the similar process as pressing firmly the power button
Remember
Pressing firmly the power button would shut down camera completely after a system check if only the camera was on.
Pressing firmly the power button when the camera is off would turn on the device by performing a system check also.
Important note
The camera when powered on would have an indicator light of ready to capture snap shots.
The camera would autoshut down when left on for an extensive duration without capturing snaps.
The instance of such would generate a camera check once more before powering off completely
The lense adds to the cameras feature capabilities of acquiring images. a function of the lense is capture an impressive image where the mechanism of drawing closer to the object is made possible by a moveable lense. The Olympus FE-340 Digital camera is powered by a battery requiring sufficient energy for a snap shot. keep in mind that, the camera can perform without the lense. However, the device is designed to automatically responded whenever the lense is required.
Important note;
1 a solution to the camera is with the source of energy in which instance batter power.
2.Dislogde the entire power area consisting of battery, check for improper installation; reinstall the battery in appropaitely noticing the installation indications of power supply. Cover the battery compartment properly, and charger afterwords.
Caution
1.Charge the battery for the entire duration known of a full charge.
2.Unplug thereafter when the full charge indicator is visible.
3.Try on the device for improvement in situation by taking photo snap shots
Dec 02, 2010 | Olympus FE-340 Digital Camera
My olympus FE-280 will not turn on. I put in a fully charged battery and when I press the power button the light on the back blinks red and the lens opens and closes about four times before completely...
There are many sides to the fault but it seems that you have a serious one. The camera needs to be opend to confirm the fault and so it needs experienced hands. The possible fault could be failure of the electronics, maybe the shuter drive, the lens drive or maybe the flash section. Assuming that your battery is good the fault can be related to a shorting or power related malfunctioning. Disconnection of one of the sectionmay be needed to confirm but an access to the camera electronics is a very sensitive job . so take help and hope the fault is economical. Good day
Aug 10, 2010 | Olympus FE-280 Digital Camera
Camera stuck with lens out & wont turn on =/
This happens with many cameras, whatever you do, do not force the lens back. You will see this as a suggestion on some blogs. Doing it might further damage the camera lens and other parts.
Here is a repair place that is very reliable: http://www.teleplancamerarepair.com/Olympus_FE_FE-370
WHen sending it in make sure you cushion it so it doesn't get worse when shipping.
Jul 04, 2010 | Olympus FE-370 Digital Camera
Blury pictures
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Mar 14, 2009 | Olympus FE-370 Digital Camera
Olympus fe-210 screen probloms
try the power reset by pressing the power button for about 10 seconds with batteries out... if this does not work then repair
Aug 30, 2008 | Olympus FE-210 Digital Camera
Camera will not power on
I've got the same exact problem and I have no idea what's wrong with it. I'm taking it to Best Buy today to try and figure out why I can't turn it on.
Apr 21, 2008 | Olympus FE-230 Digital Camera
Olympus FE-330 Digital Camera Logo
318 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
