Question about HP Compaq nx9110 Notebook
Screen is dull while on ac power. When running on battery screen brightens up but battery does not last long. Power supply is supplying 19.17 volts which but on the power supply is written 18.5 volts.
  • Alexander Slocum May 11, 2010
    have you checked the voltage where the board makes contact with the battery? This may be a dc jack issue.
  • 31 Answers
Ery adjusting your brightness via the function keys on the keyboard also under power settings see if screen is set to save energy when using ac power usually this is set to save power when on batteries it just might be reversed on your machine
Posted on Dec 12, 2009
  • 21 Answers
Goto control panel, power management, turn on full poer when on AC
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
My sons Dell Vostro 1500 has a problem with the AC adaptor. It will run the laptop but wont charge the battery. Any help will be appreciated. Thanks,David
If it will run off the AC Adapter but won't charge the battery then odds are it is the battery that won't take the charge and not the AC Adapter's inability to charge anything.
Google "dell vostro1500 battery" and change to shopping. You will see many available knock off battery's starting at 20 dollars.
Although AC Adapters go out too. They last a lot longer than batteries do. Today's batteries just don't last. I would say average life span is a year to a year and a half.
Jan 28, 2011 | Dell POWER SUPPLY Power Supply
Refrigerator doesnt cool and is showing only 6.75 volts
They need 12-14 volts to run correctly. Is it in an RV where the batteries are low or bad or does it have a power supply/rectifier that is supposed to feed it 12 volts? If so, check that power supply/rectifier. If it can run off 120 ac it may have a rectifier built in to check.
Nov 25, 2010 | Dometic Refrigerators
Screen will not brighten
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Sep 05, 2010 | Dell Computers & Internet
T23 2647 Think pad AC power adapter lost
No. You must use a power supply that is 16 volts or that is specified to be used with the laptop.
You can find the information about the power consumption (volts and amperage) underneath the laptop. If it says 16 volts then you MUST use a 16 volt power supply.
If you try using a 19 volt power supply you run the risk of damaging the motherboard or blowing the motherboard completely.
Regards.
Mar 18, 2010 | IBM Computers & Internet
No power, no lights on laptop
I think you should check the real power supply ... 120 V in and what comes out ... volts (ac - dc) and amps or what fraction of an amp.
Please compare the old with the new power supply. The new power supply should be the same volts - same kind (AC or DC) and at least the same amp rating. You can use higher amp rating but not lower - lower will burn up - literally)
Volt meter ... always set it above the suspected voltage. Batteries are always DC. Houses, buildings, etc always AC. Power supplies - could be mixed - ac in and dc out.
So if you were measuring in your home, you set the meter to 130 or higher on the AC scale. If you were doing your auto, 24 volts DC (or so).
House current, probe color doesnt make any difference. Should read about 120 Volts between the narrower (or right side/ground down orientation) or the two slots and the wider of the two shots (wide should be the neutral side - ground on the bottom). You can prove the hot side by measuring to the ground. White wire to ground = no reading. Black wire to ground = 120 volts. (The black and white are INSIDE the electric outlet. You can use either probe to do the measurement.
I hope this helps you.
If you have more question, please let me know.
Thanks for using fixya.com
a
Oct 23, 2009 | E-Machines M5309 Notebook
B&D 400W Inverter won`t run my laptop
even the smallest inverter can run a laptop, something is wrong with this unit
Jul 25, 2009 | Black & Decker 1000w Power Inverter
I Have a Toshiba satelite laptop. It has a week battery. It can't be swithed on when the battery has been removed so that it should be using AC power. But when I put in the battery and plug the pc to the...
you have a bad plug on the end of the power supply a loose jack on the computer or a bad power supply you need to test the power supply with a volt meter to see if it is putting out any power if it is you have a bad connector on the pc or an intermittent connection on the power plug end. get a new battery before you blow something up. it is not good for the power supply to run the compputer all the time. it will shorten the life.
Jul 18, 2009 | Battery Technology Computers & Internet
Ibook g4 rebuild
Hi there.
Make sure you have the voltage and amperage right first before you try and power up the motherboard.
Most laptop motherboards run on 15, 19 or 20 volts and take a different amperage like 3.42A for example.
The power in will be displayed underneath the ibook so take a look there.
Don't plug a 24 volt power supply into it unless it specifies that because you could damage the board.
Good luck with project
May 25, 2009 | Apple HQRP Replacement Laptop AC Adapter /...
Display brightness
That poroblem comes from your Motherboard and there are some trasistor that we be remove and resold anotherone where did you stay because this will be feine to an engineer to sit down and tackle the problem
ok
Rata this solutio
Aug 30, 2008 | Compaq Presario R3000 Notebook
HP Compaq nx9110 Notebook Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
