Question about RCA DRC220N DVD Player
No sound when playing dvd or cd
When playing a dvd or cd on my RCA DRC220 dvd player there is no sound. Sound works when tv is used alone.
  • Anonymous Mar 15, 2014
    how do i connect nad t567 to the c315bee amp with only rca sockets to get sound through the speakers.can i play a cd & get sound to the speakers without the tv on ?
    Sergeant:
    Champion:
  • 201 Answers
  1. Check aux cables should be in Left and Right fornt speakers
  2. Check your dvd sound Settings under menu mka sure the downmix is stereo
Hope ths help
Posted on Jan 04, 2009
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
My portable rca dvd player makes loud sound when playing dvd dvd player # drc96090
the cd is touching the base while it is spinning...i came across a similar problem and used a flathead screwdriver and gently pry the cd plate upwards so there is a little space ...otherwise take it to a repar shop...
Nov 03, 2013 | RCA 20F610TD TruFlat TV/DVD
How to connect samsung ps50c55og to sony dav s500 home theatre system
You need a set of normal rca cables (red.yellow,white) and another single rca cable..
OPTION 1 :If you have a digital satellite receiver, Connect the 3 colour cables to the corresponding colour jacks on VIDEO 2 of your dvd player to corresponding colour jacks on the VIDEO OUT Of your digital satellite receiver...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 2 STRAIGHT TO TV: connect the 3 colour cables directly to the corresponding colour jacks on the SIDE of the tv...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 3 IF YOUR PLAYER HAS AN OPTICAL INPUT: if this is the case you can just connect a single optical cable to the optical ports on your player and tv and this will enable the sound from your tv to play through your dvd player as well
Feb 12, 2013 | Audio Players & Recorders
There is know sound output when i play a cd/dvd how can i fix this
That will depend on how you have it wired in....
If you are using composite or SD video, you need to connect separate audio cables (round red and white RCA connectors) between the set and the CD/DVD player.
An HDMI connection carries sound and video and if available, should work (this is dependent on the manufacturer of the player- not all will place CD sound through the HDMI connection)
If you are using regular cable coax connections, make sure the TV is on the same channel as the OUT jack on your CD/DVD player. Again, a CD may not play sound if connected in this manner.
If you are using the component video connections (usually a red, blue, and green RCA jack) you also need to connect the red and white audio cables.
Jan 28, 2011 | LG Televison & Video
My dvd player is a jvc oct. 1999 it is connected to the tv. through a modulator, all the wires hooked up right for sound. The t.v. sound works but when the dvd plays it does fine but no sound. the serial...
Are you by chance using a SVGA cable alone? I am not sure of your cable configuration, but the SVGA cable only sends video.. this sounds like your issue. Check your cables to the modulator box from the DVD to make sure the RCA jacks are from audio l/r out on the DVD to ausio in on the modulator.. hope that helps..
Stan Skaggs
Sep 28, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Help w/ Bose Lifestyle 12 system
Does your TV have a pre-out double RCA panel connector? Some TV´s have to be told which output to use for speakers. (Additional or within..) Check settings on the TV, and possible other RCA connectors, check the in/out symbols (should say output), and try again.. If you are sure the RCA´s on the system works, the problem would have to be the TV/settings or maybe the cable..
M :)
Dec 02, 2007 | Onkyo TX-SR500 Receiver
RCA DRC220N DVD Player Logo
523 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
