Question about LG KE820 Cellular Phone
It keeps on typing down and it wont stop - LG KE820 Cellular Phone
The drain keeps stopping up
Since there is no description of what type of freezer, I will talk generic. Most freezers have some sort of drain heater. Commercial walk-ins use them. 2 types: an insertion type that go inside the drain and another type that is wrapped around the outside of the drain and then wrapped with a foam type insulation call armaflex. hope this helps some.
Jul 28, 2017 | Freezers
1991 Suzuki Swift GTi very low idle and stalling
Oxigen sensor. Check accelerator pot also, and fuel pump.
Jan 13, 2013 | 1991 Suzuki Swift
Im using my mom Dell latitude D600 PC Laptop and It was working good then all of sudden S key wont Stop typing itself Till we press "r or T" it making it hard when it pops up out the blue. it...
It seems that your laptop keyboard is not working any more. you need to buy new keyboard for ur laptop or if you want to use usb keyboard then remove this keyboard's cable, connect your usb keyboard it will work.
Aug 21, 2011 | Dell Latitude D600 Notebook
I start typing and my keyboard contunie typing one letter for Example: Youtubeeeeeeeeeeeeeeeeeeeeeeee.... And it wont stop!
It looks like the e key is stuck down and this is causing eeeeeeeeeeeeeeeeeeeeeee
It is like holding down any key on the keyboard.
Jul 13, 2011 | Apple (076-0982) Keyboard
MY COMPRESSOR JUST KEEPS RUNNING AND WONT REACH MAXIMUM PRESSURE AND SHUT OFF. I CAN SHOOT NAILS BUT IT WONT SHUT OFF DOWN.
The compressor itself sound like it is bad. You might see what it cost to repair it. It might be cheaper to get another one...keep in mind if you do a lot of work with it that a 2 stage compressor will cool better and you won't have this type of problem again.
Oct 19, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Car stops after afew miles and wont start till it cools down
Try checking your coolant. see if that needs to be replaced.
May 20, 2009 | 2003 Jaguar X-Type
Hp printer
hi,
it would be great if you can tell me the operating system that you are using on you computer.
anyways check this out:
for windows xp:
>click on start-->run
>type in services.msc
>press ok
>from the new window called services local, double click on print spooler
>press the stop button
>now press the start button
>press ok and come out of that window.
>close all the windows and restart you computer.
for win vista:
> click on start, inside start search type in services.msc and hit enter.
> then follow the same as above
Mar 14, 2008 | HP DeskJet F380 All-In-One Printer
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
My display has gone crazy
You might have a break in the flat ribbon cable that connects the faceplate to the mother board. Those types of cables often get a break in one or more to the traces (wires) that they are made of.
Jun 29, 2007 | Kenwood eXcelon KDC-X769 CD Player
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
LG KE820 Cellular Phone Logo
23 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
