Question about i-mate Ultimate 6150 Cell Phone
Start up screen is white.
Suddenly it started to show white start up screen and nothing else can be seen. Strted suddenly ,not after any fall or anything.
When i start using my laptop , suddenly white screen and forcible shutdown,.
It sounds like it's overheating, make sure the airways are clear of dust and listen for the sound of the fan inside, this could have failed..
if the processor overheats it automatically cuts out and what you describe is exactly that..
good luck !
Mar 30, 2017 | Computers & Internet
For the last 3months,my dell vostro 1088 laptop has started giving a lot of trouble.While i'm doing working on it,the screen suddenly starts blinking and it all goes white within a second.This pro
  • Remove the battery and disconnect the power cord.
  • Press power button for a few second.
  • Connect the power cord. Press the power button to start and then dock the battery.
  • White screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard. The issue can arise with the motherboard or the screen might contain a defect.
Aug 22, 2012 | Dell Vostro 1088
Shows incorrect depth suddenly and Erratic displays
MY XD510c works fine then flashes 2.5 and fills the screen with black red blue white vertical lines...then after an amount of variable amount of time goes back to working for awhile
Jun 23, 2010 | Lowrance X510c 5" Screen Color 200 Khz...
Shut down suddenly now keeps trying to start
Dear what you tried is best only apart from there no solutions from front end, check your system is rebooting or not. Please take backup of all data from your harddisk then put recovery C.D for restore your laptop O/S .
Feb 26, 2010 | Acer Aspire One PC Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Intel Pentium IV Trouble (40gig)
os not found usually means that your hd is faulty.
try remove hd and reseat it.
if no joy have os disk(windows) in cd drive start pc and boot from disk.
select install windows...system checks drive and informs of existing os..want to continue...install windows...next screen shows partitions.choose to delete partition then create new then format and install.
if when u try to boot from disk system say no hd found then hd is damaged.
Mar 14, 2008 | Computers & Internet
i-mate Ultimate 6150 Cell Phone Logo
69 people viewed this question
Top i-mate Cell Phones Experts
270rexton
270rexton
scntech1
Level 1 Expert
Marvin
Marvin
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
