Question about Metz 45 CL-1 Flash
I am using the flash with Canon A1, some times the unit doesn't flash. On and off it flashes. What could be the problem, I replaced the camera cable as well.
  • 691 Answers
Hello
Thank you for using FixYa for your problem
So you replaced the cable between the camera and the flash, it could be a contacts issue (use a electrical contact cleaner) or there is a fault in the flash unit. Do you have a spare camera you can test with
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Dec 12, 2009
SOURCE:
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
What external flashes can be used for canon cameras?
Any current or recent Canon flash unit will work fine. Most current or recent third-party flashes will also work, though you may not get all of the features you might with Canon units.
Older flash units designed for film cameras tend to have a higher trigger voltage. Using such units on new digital cameras can damage the camera. Here is one list of flash units and their trigger voltages.
May 11, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
Vivitar 3200 flash with Canon EOS Rebel T3
it will work with your rebel t3 just set the flash on manual mode and adjust the desired flash power needed .
Jan 16, 2012 | Canon Rebel Cameras
It doesn't show images in the monitor and at the same time it doesn't take pictures. thanks and more power!!!
your question is not clear. I see technical point of view. you first should disable flash mode (flash off mode), many case the flash circuit continuously force powering on whenever camera switch on and user can not use momentarily. But you can use only in day light condition if the problem condition. If not, it is shutter unit is effective that can work properly. The shutter unit is inner lens unit assemble. You should then consult to local camera tech. Thank and best regard!
May 21, 2011 | Nikon Coolpix 4300 Digital Camera
I have a Canon EOS 40D camera. We are having problems with using an external flash. The pictures always come out extremely dark with the external flash. The flash seems to work fine, it flashes...
I don't know if this will help and this post is two months old. The camera store may be right that the synchronization is the issue which tends me to point a finger at the external flash. There are at least three different flash units that will flash when the picture is made but only one type will sync with the camera. A digital flash unit is different from a film flash so a Canon EX type is required to sync with Canon TTL or TTL II digital cameras. An EZ will flash but it's off a bit, so I can only assume that your Promaster and Canon flash units are for film cameras. Okay and another thing that could be throwing things off a bit is the camera may have been programed in Custom Functions to use "Second Curtain" or "Rear Curtain". Just seams to me if the built in flash works then it's the external units at fault.
Oct 17, 2010 | Canon EOS 40D Digital Camera
I have a metz 60ct-1 flash with a dry cell battery pack. Can I use it with the canon 50D digital slr. if I use the external sync,or would it hurt my camera because it has to much voltage?
Hi I just purchased the same unit last week. DO NOT PLUG IT INTO A DIGITAL CAMERA DIRECTLY.
I got very good advise from KEH photography located in Atlanta.
The voltage is too high from this flash and will destroy the circuits in the new Canon digital camera. You need a module called the " Safe sync " This unit clips onto your new digital camera, ( were the normal Canon flash fits ) and has the "PC" ( the little round connector input ) for the Metz control cable,
I am an electronic technologist, and still suggest contacting your local photo shop.I know electronics , but not all the photo stuff. Snap away and be happy!
G. Evans
Ontario, Canada
Jul 08, 2009 | Metz 60CT-1 Flash
My Canon Powershot SD880 is emitting smoke.
This appears to be a common problem with Canon SD series cameras and especially common with the SD880. Canon must be aware of the problem, and since they have not recalled the cameras they must think it is not a fire/injury hazard. Distribution of the SD880 was suddenly stopped despite excellent reviews. If enough of us tell Canon we want these cameras fixed or replaced, even if they are out of warranty, maybe they will FixUs!
May 21, 2009 | Canon PowerShot SD880 IS Digital Camera
The flash doesn' work
Hi
Either your flash unit is defective and needs to be replaced, or the mainboard is defective and causing the flash to not work. The only way to know is to start with the flash and replace it, if that doesnt work its the main PCB.
We are an affordable digital camera repair business, if we can be of any assistance with the repair please let us know!
Good luck from Darntoothysam com
Thomas
Oct 25, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
No problem just given a box with a canon camera and a vivitar 2800-d flash
A1 = Auto setting number one
A2 = Auto setting number two
M = Full power output of flash
atdlee@netzero.com
Dec 24, 2007 | Vivitar 2800 Flash
Can the conventional Maxxum/Dynax flash units be used with this camera?
Yes. The following Minolta dedicated external flash units are compatible with the DiMAGE A1 for automatic flash control: Program Flash 3600HS(D), Program Flash 5600HS(D), *Program Flash 2500(D), Macro Twin Flash 2400*, Macro Ring Flash 1200*. * Program Flash 2500(D) will be available around August, 2003. *Macro Flash Controller is necessary
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Metz 45 CL-1 Flash Logo
99 people viewed this question
Top Metz Cameras Experts
Doberman
TimHu
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Metz Camera Expert? Answer questions, earn points and help others
