Question about Frigidaire FEQ1442ES Electric Dryer
Frigidaire dryer won't heat
Model # flgb43rgs1
It runs but there is no heat. Thought it could be the thermal limiter but don't know if it has one or where it is located.
  • Anonymous Mar 10, 2008
    Dryer heating element is not working.
The Thermister on the blower box can be bad causing the unit not to heat I had one do that . its a cheep part. take off top then remove front and its in front of blower housing . thanks jim
Posted on Jan 20, 2008
My dryer suddenly stopped drying today. It just blows cold air. Before I took notice of all the lint in dryer, I took the heating element coil out which doesn't look damaged.
The lint MAY have caused a thermal limit fuse to blow out. If that is the case then it has to be replaced. There is also a chance that the heater element has failed and as you saw it is like a light bulb coil. You need to inspect it very closely if you don't have an ohm meter to test it for continuity. Frigidaire 131553900 Heating Element Assembly PartSelect
and
Frigidaire 134120900 Thermal Limiter Limit 220 PartSelect
Dec 18, 2017 | Frigidaire Dryers
Model #CEDX563JQ0 Crosley Dryer won't heat and getting current
I would check to be sure you have 220v going to Dryer. Possibly timer problem as heat circuit runs through that too.
Aug 27, 2017 | Crosley Dryers
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Maytag Neptune Model #MDE5500ATW How to tell if the thermal fuse is blown
If this THERMAL fuse is blown it would not operate at all. If it runs but don't heat it probably is a limit or the heater. If you see a lot of junk in the vent pipe AND it still runs then the heater limits are gone. If the vent it clear but filter housing or blower has an issue then it won't run and the thermal fuse is gone bye bye.
SERVICE MANUAL for slopefaced dryer
Sep 03, 2012 | Dryers
Dryer runs but won't heat
You will need a professional to diagnose the thermal limiter, small version of a fuse, heating element and the dryer/blower assembly.
Aug 17, 2012 | Frigidaire Electric Dryer
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Now that I have replaced the thermister on my Frigidaire Gallery Series 2004 electric dryer not only does it not produce any heat, though the blower works, the motor which turns the drum is not working...
Do not replace the control board unless the necessary troubleshooting is done to eliminate the other possible causes of the problem. The dryer will not heat if the motor doesn't run because the heating circuit is completed by the motor centrifugal switch which the motor activates. The problem with the motor not running must be determined and addressed first.
Disconnect power and with the top panel removed, locate the thermal limiter, a non-resettable fuse, mounted on the rear wall of the dryer.
Bypass the thermal limiter by disconnecting and joining the wires together. Reconnect power and start the dryer. Replace the thermal limiter along with the high-limit thermostat if the dryer starts and the problem with the motor not running is solved.
Let us know if the dryer still doesn't start and/or the drum lamp doesn't turn on when the door is opened with the thermal limiter bypassed for further advice.
Jan 29, 2011 | Dryers
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
Frigidaire Dryer GLER341AS2, tumbles but not heating
I would say your right on track, check your heating coil when you locate it also...just in case.
Good luck,
Hope this helps...
Oct 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
154 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
