Question about Car Audio & Video
1994 ford ranger stereo replacement
Ran into what apears to be a stock amplifier. can I remove it at the harness and utilize my own?
    New Friend:
Keep asking about where a stock amp is located in 94 ford explorer but get nothing..anyone know
Posted on Jun 29, 2013
  • 65 Answers
Yes you can. As small as a Ranger is, I would recommend running new speaker lines direct from the new amplifier, through the door harness and into the speakers
Posted on Jan 21, 2008
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
How to install a Kenwood kdc 138 in a 1992 Ford Escort LX?
if its anything like my 92 ranger you take the dash apart around the radio and the stereo should unscrew, in my ranger the new cd player went in without any extra harness as it was the same size as the stock, if not you can but harnesses to go where your old stereo did, to connect the speakers you can buy a ford wiring harness from walmart or any store with an audio department. these plug in to your vehicles wiring harness so you don't have to cut it out, after that you simply match colours from the wires of the new cd player to the wiring harness
Dec 25, 2013 | Kenwood DISCONTINUED - KDC-138 In-Dash CD...
How to replace headlight switch 1994 ford ranger
take the dash apart so as you can get to the switch, unbolt and replace
Sep 28, 2012 | 1994 Ford Ranger Supercab
I have an 02 ford explorer, the previous owner had a custom sound system installed. He took allof trhe custom speakers and amps out but left the stereo in,but it does'nt play. the stereo work ands powers...
sounds the like the vehicle had an oem amplifier that was removed, most after market stereo installers will trace the speakers wires individually by continuity to by pass the factory amplifier and wire the new head unit to the vehicles speakers, if the harness has been spliced or factory amp removed, you will need to check if the amplifier still exists (usually under passenger rear seat sometimes located in trunk area) and see if the harness has been bypassed. if so you will have to reconnect the harness by color code in order to use the factory head unit
Feb 18, 2011 | Ford Explorer Cars & Trucks
Need wiring guide for replacing stock radio 1996 ford windstar with Dual Model XD 1222 radio have harness still need wiring assistance
I would get an adapter harness that will plug into your existing vehicle plug, and the wires are color coded to match up to most aftermarket stereos. You could check e-Bay, or a local automotive audio store for the adapter harness.
May 10, 2010 | 1996 Ford Windstar
I have 97 for ranger with tape deck with cd player
This should help you wire up your new stereo. 97 Ranger stereo wiring diagram. They do make a plug in harness for your truck. Metra part number 70-5600.
May 10, 2010 | 1997 Ford Ranger SuperCab
What colors go to what colors of the stock wiering
If your car does not have an amp. use this wiring harness
Metra Electronics Corp. 70-5600
FORD Ranger/Explorer 1995-Up - Into Car. I f you car has amp. you need this one Metra Electronics Corp. 70-5603
Factory amplifier integration harness. I recomend you to by one of this wiring harnes is easy for you.
1998 Lincoln Navigator Car Stereo Wiring Diagram
Radio Battery Constant 12v+ Wire: White/Violet
Radio Accessory Switched 12v+ Wire: Black/Pink
Radio Ground Wire: Black/Green
Radio Illumination Wire: Blue/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow/Red
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Blue/Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Violet/White
Right Rear Speaker Negative Wire (-): Light Blue
Jan 16, 2010 | Car Audio & Video
I am trying to install a new stereo in a 94 rodeo but my wire harness is cut off
here are the wire colors and what each does.
1994 Isuzu Rodeo Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Brown/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue/Yellow
Left Front Speaker Negative Wire (-): Yellow
Right Front Speaker Positive Wire (+): Green/White
Right Front Speaker Negative Wire (-): Gray/White
Car Audio Rear Speakers Size: 4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Red/White
Right Rear Speaker Positive Wire (+): Orange
Right Rear Speaker Negative Wire (-): Black/Orange
Nov 22, 2009 | 1993 Isuzu Rodeo
Need photo schematic for replacing Brake Light Switch
the brake light switch is on the top part of the pedal unplug electrial connection remove clip that holds switch on pin remove switch and reassemble
Jun 03, 2009 | 1994 Ford Ranger Supercab
Wiring harness doesnt fit my 1989 lincoln towncar
i had the same problem and found out that i bought the wrong harness. there are two styles one for non-amplified and factory amplified.
Oct 10, 2008 | 1989 Lincoln Town Car
Car Audio & Video Logo
613 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
