Question about Cutler Hammer Main Lug Load Center, 60 Amp
Is there a minimum amperage for a single family dwelling? The current residents would like a panel change, but only currently have a pull out and screw in fuse style panel. I would tell you more about the current panel but all stickers and plackards were removed and there is no name brand or amperage listed anywhere on the fuses, tub, or cover. I believe it be only a 60 amp. I guess to conclude, what I am asking is, can I remove the current 60 amp panel, which is feeding the entire dwelling, and replace it with another 60 amp, breaker style panel? thanks, andrew
    President:
  • 1,214 Answers
Per NEC code and local ordinances, no.
This type of work is only to be done by a licensed electrician, and requires that the electrical system be brought up to current code.
That being said, you can do it, but you better know what your doing as there is likely no way to kill incoming power from the meter without pulling the meter. And pulling the meter will violate power company agreements with the property owner.
You also risk liability in the event someone is electrocuted for whatever reason, even if not directly related to what you did.
Any plug in the bathrooms or kitchen within 6 feet of a sink are to be on GFI's, and you can't add a GFI as it's very likely the current wiring does not include a ground.
Posted on Dec 12, 2009
2003 carrier weathermaker 38tkb unit 40,000 btus 10.5 seer 3.5 ton - what should start amperage be?? is 132 too high tks
as you are running 2.5 or 3 mm wire for the unit , at 132 amps the wire would melt
check the setting of the amp meter as it is more like 13.2 amps which would be about right
use an example , check the size of the wires from a battery in a car and that size wire carries 400 amps minimum when starting a car, then check the wire size to the unit
all compressors start with a high current draw ( 25 amps ) but it drops of to running current after a 1/2 second or so
May 24, 2016 | Carrier Heating & Cooling
How many amps in the Vision Fitness T9500 HRT Treadmill
it is a 3 horsepower motor, but no amperage specified. The review does say this model has drawbacks.
Vision T9600 HRT Comfort Treadmill review
However, I found this, so 23 to 28 amps based on a 3HP motor.
Note: the following table contains approximate full-load currents for motors of various types, speeds, and frequencies. Variations of ±10% may be expected.
Hp. of
Motor
Current - Full-Load (Amperes)
Direct-current Motors
Single-phase Motors
115
volt
230
volt
550
volt
110
volt
220
volt
¼
4.8
2.4
½
4.5
2.3
7
3.5
¾
6.5
3.3
1.4
9.4
4.7
4.2
1.7
11
5.5
1 ½
12.5
6.3
2.6
15.2
7.6
8.3
3.4
20
10
12.3
5.0
28
14
Oct 06, 2015 | Vision Fitness Exercise & Fitness
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
What is a Co-Current protein skimmer?
Co-current protein skimmer is one of the methods used in aquarium water skimmers. The air source is on the bottom of the reaction tube. Water is drawn up into the chamber with minimum dwell time. This skimmer is the least efficient of all skimmer designs.
Aug 30, 2012 | A H Fabrications Fish
How do i change my acer login password
Lost Acer Windows 7 Logon Password? ' How to reset Acer Aspire One password if you don't know it?
  • The netbook is redefined with the arrival of the Acer Aspire computer and many people like it. Sometimes, you lost Windows 7 logon password, how to reset it on your Aspire laptop?
May 14, 2011 | HP Mini 1000 Netbook
What amperage breaker required for neptune 5500 dryer? Also, it shows 120/240 volt on back canit be wired for 110 current? Thanks, Mark
No it can NOT be wired for 110 .Actually everything it the unit runs on 110 volts except for the heating element which needs 220 volts..As far as the circuit breaker is concerned you need a minimum of 30 amps
Nov 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
If using with a power strip or extension cord, how many amps does the iron pull -- it is 1700 watt the kind I have
Power = Current x Emf
Current = Power / Emf
Current - Amps
Emf - Volts
Power - Watts
Current = 1700 watts / 120 Volts = 14 Amps
If you live in Europe then -
Current = 1700 watts / 240 Volts = 7 Amps
Be sure your breaker and extension cord are rated for the amperage.
Nov 19, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Current in Neurtal wire
First, what country are you residing in? There are questions regarding what type of system you have to whether the current readings are true RMS. Assuming this is a WYE connected system, the current flowing through a neutral wire are not hazardous. The system can be slightly unbalanced, meaning one or two phase legs is carrying more or less load than the first phase leg. Ideally we would like a minimum amount carried on the neutral but being in the real world, it is only theory.
May 14, 2010 | Electrical Supplies
What size main breaker do I need for a 125 amp panel?
You can install anything, up to a 125 amp. Just do not go any higher amperage then that. Anything lower will work just fine but will limit the current to the amount of the size of the breaker.
heatman101
Mar 26, 2010 | Cutler Hammer 100 Amp Main Breaker...
Resident evil 4 does not launch
Please try to see if your Resident Evil 4 is properly installed or it passes the minimum hardware requirements as posted below.
Hardware Requirements Supported OS: Windows® 2000/XP (only)
Processor: 1 GHz Pentium® III or AMD Athlon (or better)
RAM: 256 MB
Video Card: 128 MB DirectX® 9.0c-compliant AGP or PCI Express graphics card (256 or higher for High Graphics Detail support) (see supported list*)
Sound Card: DirectX 9.0c compliant (or better)
DirectX Version: DirectX 9.0c or higher (included on disc)
CD-ROM: 12x or faster CD-ROM
Hard Drive Space: 1.2 GB minimum
Peripherals Supported: Gamepad
*Supported Video Cards at Time of Release
NVIDIA® GeForce FX/6/7 families
ATI® Radeon® 9200-9800/X families.
Note: if your hardware meet the minimum and recommended requirements then the problem is either the installed program that is not installed properly or the installer it self.
Thanks
Aug 15, 2009 | Video Game Consoles & Games
Cutler Hammer Main Lug Load Center, 60 Amp Logo
48 people viewed this question
Top Cutler Hammer Electrical Supplies Experts
Craig Butler
Craig Butler
Spencer Field
Spencer Field
Level 1 Expert
Gene Haynes
Are you a Cutler Hammer Electrical Supply Expert? Answer questions, earn points and help others
