Question about Sony STR-DE845 Receiver
Receiver making alot of clicking noises.
I've had this receiver for several years. About 2 months ago, it started making a bunch of clicking noises. About every 5 minutes, it will click about 5 times, then stop for about 10 seconds, and do it again. Is it on it's last leg or what. Sometimes, right after the clicking, the speakers won't sound the same for a few minutes, then go back to normal. Any help would be appreciated.
Thanks,
Richard
  • 3 more comments
  • klaus161 Jan 28, 2008
    I have a STR-DE845. It just recently started the clicking and no sound problem. It first started when someone would walk by the receiver or bump it. I noticed that when I move the speaker selection switch side to side, it will click off and back on. Sometimes I can get the switch to stay on for a while but it always goes back off later.
    Does either of yours do the same thing? Think it is a bad switch? Where can you get parts for a Sony receiver?
  • rrkbeal Jun 22, 2008
    Bought my reciever in 98' the clicking first started in my center speaker than went to my rear speakers. Only the front speakers work
  • Anonymous Oct 24, 2008
    I have this receiver more than years, and now Sometime i have a problem, right after the clicking, the speakers won't sound the same for a few minutes, then go back to normal. Please help me fix this problem!
    Thank you!
    Dennis.
  • markworden Nov 04, 2008
    I have the same problem with the front switch and the 'clicking' A electronica repair shop (they talked to me) believes this would be a cold-solder-joint. So there is most likely a solder connection that was weak and has come loose after all the years of us pushing the power button and switching channels for the speakers. No I have not tried to fix it yet, that will be my winter project.
  • blfesper Dec 05, 2008
    I'm hearing a couple of clicks every so often from my STR-DE845, but not as often as some others have described, and it seems random. It is the same set of clicks as if it is changing inputs or turning on.
    It has also intermittantly turned off the front speakers, powering only the center and rear, with all components, and even after rewiring the connections and trying different speakers.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Posted on Jan 28, 2008
Left front speaker channel not working
Check that the green plug is properly inserted or it is not bent
Dec 09, 2014 | Pioneer VSX-D307 Receiver
The receiver for my wireless mouse just suddenly started freezing my Vista machine from booting. Just a blank screen with cursor flashing. But if I remove it before booting, it boots fast, then plug i
Try looking for a "patch" on the manufacturers website. You did not supply the Make, model of your machine.Are your windows vista updates current?
Nov 18, 2012 | Computers & Internet
About a month ago my speakers started humming-does't matter if the cable/dvd are on, as long as the receiver is on it hums. Figured out it was the receiver since I plugged other speakers into my...
normally a Hum is caused by a bad ground,, if it only happens when the unit warms up it could be the output drives are failing. , check the grounds to the unit first, then the wires to the speakers themselves, if they all check out ok,, you need to take it to a repair shop dealing with receivers
May 27, 2011 | Yamaha RX-V1600 Receiver
My Denon AVR-788 receiver switches off by itself after it has
If you've changed it's location or added speakers, or placed anything on top of it since the problem started then consider that it may just be over heating.
Dec 19, 2009 | Audio Players & Recorders
Denon AVR788 has a clicking noise
The clicking noise is the protection circuit that is kicking in and repeatedly shutting off the unit because an internal fault has been detected.
If the problem happened before a power surge, and the power supply looks damaged, then the PSU must be replaced.
If the unit is only 3 months old, better contacting Denon and having the one year factory warranty validated, rather than DIY.
See : Denon USA | WARRANTY or contact Denon for more info on your limitede warranty cover.
If the unit has been taken apart, this may invalidate warranty.
If you want to DIY you can find parts here, or from Denon.
Do not forget to leave feedback.
Thanks.
May 15, 2009 | Televison & Video
Dell 964 AIO will not work just makes a fast clicking noise.
yes, the old printer has a broken tooth. it is going to cost you the same in repair as to buy a new one.
May 13, 2009 | Dell Photo 964 All-In-One InkJet Printer
RCA DTC210 Directv HD tuner flashes when plugged in
My DTC210 didn't want to work after being stored for awhile. Both lights were ON but there was no output.
I left it turned on and after about 2 hours it started working.
Dec 27, 2007 | RCA DTC210 DirecTV DTV Receiver
Receiver clicks
When you say click Is it a POP out of the speakers?? If the answer is yes then it sounds like a semicondutor such as an IC or driver transistor or preamp is breaking down . You also didnt state if its out of one speaker or both at once. Unless your a tech this is probably something you wont be able to troubleshoot and fix yourself as there are no user serviceable parts in this puppy. Good luck
Jun 10, 2006 | Yamaha HTR-5830 Receiver
Sony STR-DE845 Receiver Logo
401 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
