Motherboard don't know value/range of cyramic capasitors? could you find me a circuit diagram for toshiba tecra a2 model? thank you
  • shahnun77 Dec 13, 2009
    The problem is the capacitors was missing. I need the exact value of capacitors. So I need a diagram or you have an ideas to change/replaced the capacitors. On motherboard the number to be place them is C6074,C6078 & C6079 (cyramic capasitor), Toshiba Tecra A2.
  • 31 Answers
Check numbers on capacitors they usually tell you the values and manufacturer also you can google the numbers and get white sheets to tell you alot more
Posted on Dec 12, 2009
System and function keys are not working
https://www.manualslib.com/manual/180236/Toshiba-Tecra-A2.html?page=106
Aug 21, 2017 | Toshiba Tecra A2 Notebook
Toshiba tecra a2 screen backlight problem the is screen not lighting up at all but in bright daylight fully functioning screen can be seen could this be the lcd inverter and how difficult is it to replace
screen not lighting up is either the screen inverter or a broken tube inside the screen. Tubes don't break by themselves so a dim screen usually comes after a transport or a drop. I would replace the inverter first (just cause it's easy and cheap). eBay's a good source for inverters and screens and you ought not pay more than $5 for a used inverter and anything more than $30 for a used screeen would be considered tourist price. Tecra A2's are rare, but it's the same as the more popular Satellite A55's. Its screen should be a 15" XGA and would be the same screen as many other Toshiba Satellite models (A10, A15, A40, A45, A55) and Satellite Pro models (M10, M15), to name a few.
In my opinion, dim screens are 98% broken tubes and 2% inverters.
Jul 29, 2011 | Toshiba Tecra A2-S336 Notebook
How do i remove the key board
How to replace your Toshiba Tecra A2-S119 laptop keyboard ?
It's easy to break the flimsy keys on laptop. In order to better protect the Toshiba Tecra A2-S119 notebook keyboard, some friends, instead, use USB keyboard. But if you work outdoors, carrying a USB keyboard is not convenient. You still have to use the laptop keyboard. Once a laptop keyboard stops working, there is no option but to replace it. You can use these steps to replace the Toshiba Tecra A2-S119 keyboard.
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Tecra A2-S119 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Tecra A2-S119 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Tecra A2-S119 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
You have to remember that once you open up the Toshiba Tecra A2-S119 laptop computer for keyboard replacement, the warranty provided by the manufacturer stands void. We personally suggest that you do it on your own only if you are in a really desperate situation and there is no way you can get maintenance from the manufacturer. I hope this assists you. John
Jan 26, 2011 | Toshiba Tecra A2-S119 Notebook
I have a laptop toshiba tecra A2 with a 60 hard dish memory. I would like to upgrade my hard dish. what maximum hard dish can be use?
http://support.toshiba.ca/support/TechSupport/ln_TechSupport.asp#
link above will help you select maximum hard disk drive for the Tecra A2, since i do not know what model part number you have -- there are three to choose from
Nov 15, 2010 | Computers & Internet
I need the Toshiba driver of TECRA A2-S119 model
Here's the link where you can download all the drivers (Click Here), you'll need to select the operating system.
If you have problem, let me know with more details about your Tecra. Good luck.
Thanks for using FixYa.
Nov 06, 2010 | Toshiba Tecra A2-S119 Notebook
Drivers
how did you get here,?,go to the support site download the drivers (save) to desktop,burn them on data cd,or drag onto flash drive,then put it in the toshiba
Sep 21, 2009 | Toshiba Tecra A2-S336 Notebook
Reinstalled windows xp on tecra a2, need all drivers
Two things to try, install service pack 3 for xp, and go to the Toshiba website look up your laptop and see if they fave drivers that are compatible with xp sp2 or sp3. Hope you find what you looking for and this info helps. GL
Jun 23, 2009 | Toshiba Tecra A2-S119 Notebook
FN key not working on Toshiba Tecra A2
You can enable/Disable Fn key in System Setup.
to access system setup press F2 when you see the Toshiba logo
Mar 14, 2009 | Toshiba Tecra A2-S316 (0032017250819) PC...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
