Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave f3 problem
Cleaned air vent
  • Anonymous Feb 16, 2008
    f3 thing is weird how do i fix it
  • Anonymous Apr 26, 2009
    All of a sudden in the middle of the night, started beeping and shows F3!
  • GE Master
  • 9,098 Answers
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 24, 2008
WHAT DO YOU MEAN BY (F3 PROBLEM)? MORE INFO PLEASE.
Posted on Jan 22, 2008
Code "F3" is highlighted on Key Panel
F3 usually means a problem with the control panel. There may be a corroded component or a power surge damaged the unit. Sometimes a little water will get into the keypad and cause the problem.
First try unplugging the unit for ten minutes. That may reset error code. (For built-in units, you can try flipping the circuit breaker to off or removing the trim to reach the power cord.)
If that fails, unplug the microwave again. You can remove the vent by unscrewing the top screws. Open the door to get the vent free. Then unscrew another screw to tip the keypad down (push up at the bottom of the panel). Disconnect the wires from the circuit board and remove the screws. Remove the circuit board and the shield behind it. Check over all of the pieces for dirt or signs of corrosion. (Clean gently.) Let everything dry (or use a hairdryer to dry all sides of the components). Then replace the parts in the reverse order. Plug in the microwave and check for the error.
If that fails, replace the control panel. One source for parts is http://www.appliancefactoryparts.com/microwaves/ge/jvm1640sj.html .
I hope this helps. It may be cheaper to replace the microwave.
Jul 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave venting
Is it a combo built into the oven or stand alone?
If its build into something then no.
If its free standing look under the microwave and see if there are air vents in it. If there are are they clean. Microwaves dont vent persay, they just blow hot air out. You dont want to modifity the case because it will expose you to direct and scatter Microwaves. And that is not good.
A easy fix. When you are done making a TV dinner or whatever, keep the door open for a while. The microwave is hot and it will evaporate.
If there is standing water in it, contact the company and get them to fix it, but checking for proper intake and venting is needed. Meaning make sure they are clean.
Nov 05, 2013 | Oster Microwave Ovens
Micro has a message F3 and and none of the controls work when i push the buttons
You have one of 2 problems, an open Thermocouple or a bad control panel DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
It is all of a sudden beeping and there is a -F3- in the screen area. What do I do. It is a above the stove microwave. And has never done this.
hello,
The -F3- is an error code indication temperature sensing error. There is a chance that there is a loose wire connection from it position.
what you need to do to fix up this problem is to unscrew (open)the oven trace the wire down to the screen and also to the panel clean then fix up the loose wire back to it position then clean up all form of water or liquid you can fine around the wire and the control panel with this the problem of f3 code is solve.
than you.
Jun 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
While cleaning it the vent began to open and close and the microwave would not shut the vent down when the keypad was used to end the cycle. Now it only shows F3 on its screen when we try to set it up...
The "F3" error code means "Shorted key panel (touch pad)". The correction is to replace the key panel aka a membrane switch or a touch pad. The control panel in that case is just a plastic frame.
please rate this help to keep us online
Aug 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 error
So far so good we unplugged the machine took the filters off the bottom let everything dry out over night and it seems to be working I'll update you tomorrow. I think the steam got the control pannel wet.
Jun 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Frigidaire F3 problem
thank you, problem resolve....bought new micro
Mar 22, 2009 | Frigidaire FMV145K Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
629 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
