Question about Exceed-RC Toys
I have an Exceed FPV camera, also called a spycam. These look like a flash drive and can be used as such. My problem is that I need to set the onboard clock. This is usually done with a text file loaded in the root directory. I have contacted the merchant(NitroPlanes) and they don't know anything. Can you help?
  • 1 more comment
  • johntwatts Dec 18, 2009
    Thanks for taking the time to reply, but that is not the case. The cameras come without the text file being in the root directory. There is nothing in it at all. I know about this from another camera that was probably manufactured by the same company. The way it work was .........
    1) create a file in the root directory with the name cameraconfig.txt or something like that.
    2) in the file type....... example: 2009-12-18 14.05
    3) save the file and unplug camera from USB port
    4) take a photo
    5) plug camera into USB port
    6) check root directory - file should deleted - when it reads the file it deletes it
    7) check date on photo - correct if neccessary
    You are correct in that these cameras have caught on as onboard model plane/car cameras.
    There has to be a way to set the date and time on these cameras.
    John Watts
  • johntwatts Dec 19, 2009
    I have this camera...... http://www.nitroplanes.com/mifpvcocaupt....
    I need to set the internal time and date so that the photos/AVI's will show the proper date.
  • johntwatts Dec 30, 2009
    This is straight forward. I need to know what to name the file and how to format it. These cameras do not come with that info. The other camera that I saw used a text file to set the time/date. I can only assume that this camera would use the same technique.
  • 1,498 Answers
Hi John,
SD Cards, Mini SD-Cards, etc act just like a hard drive when plugged into a computer.
You can use Explorer and/or Notepad to browse and edit text files.
Sound like there will be a configuration file containing the date. There may be a keyword attached. The things we need are the name of the file. (If it doesn't exist, the camera may create it), the line item keyword (eg Date=12-21-2009), ant the date format it expects.
Is there an existing file? If so, are the content plain text?
This should be straight forward.
Mike
Posted on Dec 21, 2009
    Brigadier General:
  • 4,044 Answers
Well, I have searched the resources I have for anything on this camera and everything I find indicates it is some sort of camera designed to be put in an RC type vehicle. Now, since your post indicates otherwise I will approach this from the Programmers perspective. If there is supposed to be a text file in the root directory to use to set the date/time on the device you should be able to plug the device into the USB port on your computer and see that file using Explorer if you have windows. If the file exist it will be visible if you do this. You should be able to open that file with Notepad and see the entries that are entered. These are most likely 1 entry per line. If this is the case find the one for the date and use the same format to enter the correct date. This is normally DD/MM/YYYY format and the time entry will most likely be HH:MM:SS (Hours, Minutes, Seconds Regular format of time not military time) The name of this file could be almost anything but if you start note pad and then select open from the FILE menu it should only show you files with the .txt extension which should help you identify it. If you open the wrong file simply close it without saving and no changes will take place. Hope this helps.
Posted on Dec 14, 2009
SOURCE:
Transmitter/receiver pair for RC devices
Sorry I can't comment about your gear but before spending your money I advise you to check on what sort of licences you need to operate what is effectively a local broadcast station. Governments and regulatory bodies take the protection of their radio frequencies very seriously and licences for transmitting on selected frequencies can be expensive and available only to suitably qualified people.
An example of suitable qualification is a proven competency or ability for the equipment operator to be able to check and/or ensure the installation doesn't cause third party interference and if it does make suitable adjustments or modifications.
With the exception of citizen band radio I believe only low power radiation of up to 100mw can be operated without a licence and unless using a microwave link with dishes I think you will need many times that power for reliable transmission/reception. In addition such frequencies as used by CB and ham radio, continuous transmission or transmitting entertainment would be illegal.
Causing third party interference or infringing broadcast regulations often results in at least equipment seizure so please ask the right people the right questions before you begin.
Jul 06, 2015 | Audio Players & Recorders
I only get a black screen with a green line through video?
hi,
through wich port? hdmi or usb? if from usb, what cable are you using ? self made or bought one, and then, wich one, the video alone, the fpv alone, the fpv+power, the combo cable ???
Jan 24, 2013 | GoPro HD Hero 3: Black Edition Camera
Digital Concepts 952AF Power Zoom Flash For Panasonic Problem
The flash may exceed the voltage it sends to the camera. It doesn't take much to fry the electronics in the camera if the flash isn't designed for the camera.
Jun 17, 2017 | Digital Concepts GPS
In side flash not working
Unless your camera remains under warranty, repairing the flash is usually not cost-effective. Repair is not a DIY option and it must be done professionally. If you visit the Olympus website in your country and go to the service page you will often find that there is a fixed price repair menu on offer.
You may find it's cheaper to fit an external flash to the external hotshoe especially if you can buy a good used flash, but you must ensure that you either use an Olympus or Panasonic model; you may use other independent makes such as SunPak or Metz (expensive, but really worth it) but must ensure that they're suitable for digital cameras. Older flashguns designed for 35mm film cameras can pass too much voltage through your digital camera and damage it. You may also need to activate the external flash hotshoe via the menu as on most cameras it's inactive until selected. Note that an Olympus/Panasonic badged unit will give you full automatic operation, but if you use independent models then you will have to set everything yourself for "non-dedicated" models, and on more expensive "dedicated" models you may have fully automatic operation or may have to enter some settings manually. "Dedicated" flashes are those which have electronics and features tailored to particular camera brands.
Although an external flash is bulkier, the trade-off is that even lowly specified models will far exceed the output of your built-in flash. This enables you to use flash at greater distances and also provides more even illumination of the subject.
Sep 29, 2010 | Olympus SP-350 Digital Camera
I need a driver software for 16gb pen spycam
some pen cameras do not require any drivers as they are detected in regular softwares. Since you have not mentioned the Make /model search for general drivers for spyccams.
try this link
www.downloadthat.com/windows/search/anyka_usb_???spy_???pen_???camera_???driver
Sep 16, 2010 | Cameras
Lost instrctions
http://www.trust.com/products/product.aspx?artnr=13947&cxt=manuals
Download manual at this link. just select language you need.
Thank you and enjoy,
Lee
May 23, 2009 | Trust SpyCam 300S Digital Camera
Flash use "kills battery dead"
The most likely culprit is a several year old battery that is not accepting or holding a sufficient charge. Turning the camera on, and taking a non-flash photo may not tax the battery too much. However, when the flash is called for, the power demand may exceed the battery's ability to deliver enough juice. A new(er) battery is probably your best bet to resolve the problem.
Mar 23, 2008 | Canon PowerShot S50 Digital Camera
Toys Logo
66 people viewed this question
Top Exceed-RC Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you an Exceed-RC Toy Expert? Answer questions, earn points and help others
