Question about Compaq Presario SR1010NX (DW254A#ABA) PC Desktop
Configuration problems after system restore - Compaq Presario SR1010NX (DW254A#ABA) PC Desktop
  • 1 more comment
  • Mihajlo Jerkovic May 11, 2010
    What config problems? is there any messages and how for does it start up if at all and is there any beeping?
  • Laxman Bisht
    Laxman Bisht May 11, 2010
    Kindly elaborate the issue. Where exactly are you facing the issue?
  • parasrthd May 11, 2010
    In Which operating system?
    Problem Solver:
  • 13 Answers
You need to reconfig the system
Posted on Dec 13, 2009
Skype fatal error
What sort of error ? are you able to start your computer ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
or click start type in event viewer press ENTER
you might be able work your way through the problem
or
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service
you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
If the problem is hardware related the system restore might not work .?
Sep 25, 2013 | Skype IM
Shortcut keys
What have you tried ?
which operating system ?
You can use the System Configuration utility to perform a system restore.
There are three possible restore points: System checkpoints that Windows schedules
Manual restore points that you specify with the System Configuration utility
Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
Jul 22, 2013 | Acer Aspire Computers & Internet
Toushscreen do not work
Connect the screen to a computer running Windows 7 using the supplied USB cable and a cable for the video signal. Ensure the cables are properly connected. If the screen does not respond to touch, please visit our knowledge base article USB detection problems in Windows. or you might use the system to restore to resolve the problem You can use the System Configuration utility to perform a system restore. There are three possible restore points: System checkpoints that Windows schedules Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. hope this helps
Jan 08, 2013 | ASUS Eee PC T101MT 320GB Professional...
"For Atheros PCIE Ethernet Controller v2.0.2.3(05/18/10) Check Cable Connection!"
The operating system is looking for a boot device
Make sure there are no discs in the drives cd/dvd and usb
make sure the bios is set to boot from your hard drive or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem.
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode.
You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
hope this helps
Nov 25, 2012 | Computers & Internet
My laptop aspire5920g goes into configure updates and then switches off this happened when my battery ran out whilst configureing the updtes
You could try a system restore to combat this problem.
- Reboot and keep tapping F8.
- Choose 'Repair your Computer'
- Login.
- Choose 'System Restore'
Be sure to restore to a point BEFORE the problem started.
Good Luck!
Apr 27, 2011 | Acer Computers & Internet
Cannot enable sytems restore. Message: Group
1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
* Delete the value DisableConfig
* Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
More Information
Turn off System Restore corresponds to DisableSR registry value. With this Policy is turned ON, the System Restore tab may be missing in My Computer Properties. Also, when you run System Restore (rstrui.exe), you receive this message:
System Restore has been turned off by group policy. To turn on System Restore, contact your domain Administrator.
Turn off Configuration corresponds to DisableConfig registry value. With this Policy turned ON, the System Restore tab will remain displayed but the user cannot configure the SR options. It reads disabled by Group Policy.
http://windowsxp.mvps.org/srpolicy.htm
Or perhaps you can review this
Control of System Restore function has been disabled by "Group Policy".
How do regain control?Go to Start>Run, key in gpedit.msc and hit ENTER. Under Computer
Configuration, expand Administrative Templates, expand System, then click on
the System Restore folder. In the right-hand pane, double-click on Turn off
Configuration and, under the Setting tab, click in the radio button beside
Not Configured. Click on Apply then OK.
Please visit the following Microsoft Knowledge Base website
and review the topic titled: "Method 1: Use Group Policy".
How to Disable the System Restore Configuration User Interface
http://support.microsoft.com/default.asp…
Note: You must be an administrator or owner, or have administrative
privileges to perform this task.
Undo the changes using Group Policy Editor (Gpedit.msc)
-or-
Open Registry Editor and navigate to:
HKEY LOCAL MACHINE\SOFTWARE\Policies\Microsoft\Wind… NT\SystemRestore
In the right-pane, delete the value "DisableConfig".
Close Registry Editor
Close and re-open the System Restore properties page.
Note: Group Policy Editor is only Available in XP Professional (according to http://www.pcreview.co.uk/forums/thread-…
Perhaps one of these links will give you the correct solution
http://forums.techguy.org/windows-nt-200…
http://www.winhelponline.com/blog/restor…
http://www.computing.net/answers/windows…
I hope this helps you to resolve your problem.
Jan 03, 2010 | Microsoft Windows XP Home Edition
My system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
---> System
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Configuration error after trying to restore system
Go into system restore under windows system tools and rest your restore point to one prior to restoring your computer to original factory condition. Then wait until you can determine which configuration error is the problem and then restore to original settings. Good Luck
Nov 08, 2008 | HP Compaq Presario SR2150NX PC Desktop
Blank screen on acer aspire 5570z laptop
Hi Grneyes0725,
Thanks for the posting in FIXYA.
Could you please reboot Laptop in Safe mode.
Tapping F8 Key during Bootup. Select the option safe mode with networking.
Do the Error checking for each Hard Disk partition. Hope it fix the problem.
And if the problem is recent and date is known, its better to make a system restore.
1. Log on to Windows as Administrator.
2. Click Start --> All Programs --> Accessories --> System Tools --> click on System Restore. System Restore starts.
3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
4. On the Select a Restore Point page, click the most recent system checkpoint in the On this list, click a restore point list, and then click Next. A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer (normal mode now).
6. Log on to the computer as Administrator. The System Restore Restoration Complete page appears.
7. Click OK.
Best of Luck & Regards
ELLIN
Sep 14, 2008 | Computers & Internet
System Restore gets disabled
You must set the "Service" to "Automatic" here are some instructions. And a link to a M$ KB article about it. support.microsoft.com/kb/302796 Start the Group Policy Editor (gpedit.msc) Navigate to Computer Configuration/Administrative Templates/System/System Restore Set Turn off System Restore and Turn off Configuration to "Disable" Right click on My Computer and Select "Manage". Navigate to Services and Applications/Services Navigate to System Restore Service and double click On the General tab set [Startup Type] to "Automatic" using the drop down list Click the Start button to start the service. Close the Computer Management console Return to System Restore in Group Policy Editor and configure both to "Not Configured" Close Group Policy Editor and reboot the system. After the reboot is complete, right click My Computer, select Properties and the tab for System Restore will have been restored. Configure it to your individual needs.
Aug 20, 2007 | Microsoft Windows XP Professional With...
Compaq Presario SR1010NX (DW254A#ABA) PC Desktop Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
