Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
I have a kenmore refrigerator, but for some reason it's not cooling. i've check back rear fan, it's working and i'v also check the inside fan removing the inside rear panel on the freezer side, and it's also working. what might be the problem.... need your help....
  • 106 Answers
Is the compressor running?? If its hot but not running , humming and clicking sound you may have just a bad compressor relay. Or a bad compressor.
If your compressor is runing you have lost your freon.Leak or hole in system.
Posted on Dec 12, 2009
Top freezer working fine refrigerator part not cooling we've cleaned the coils
Did you check for an ice build up behind the rear panel in your freezer? It sounds like your defrost system is not working and allowing ice and frost build up that is blocking the cooling tubes to the refrigerator.
But also make sure that the evaporator fan in functional so that it forces the cold air from the freezer to the refrigerator through the cooling tubes.
Sep 04, 2011 | Kenmore Refrigerators
Freezer not freezing but cools like the refrigerator would. Refrigerator not cooling enough. the cover in the back of the refrigerator was off. I reconnected but the freezer still won't freeze
is the freezer fan running? is there frost on the rear freezer wall if so it would be a defrost issue. if no frost on freezer rear panel it would sound like a bad compressor or sealedsystem leak.
Jun 06, 2011 | Kenmore Top Freezer Refrigerator
It is still cooling but was making a loud sound unplugged it over night now it seems to be working again, what made sound and will it come back
Good day,
Motors make noise. There are three motors. One behind the rear panel in the freezer compartment.
Another in the back rear of the machine, called a condenser cooling, fan motor, and lastley, the compresssor itself which is locacated in he bottom rear as well.
One reason could be ice building up around the freezer fan motor and hitting the blades of the fan.
If it is a Whirlpool/Kenmore make then that fan motor could be going bad.
But without a make and complete model number that's all the info I can provide.
As well, we'll need to know how long it takes to re-appear, and if it is constant or intermitent noise problem.
Dec 12, 2009 | Refrigerators
Fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | Kenmore Refrigerators
Kenmore 61042 fan motor replacement
hi! you mean there is ice on the part of evaporator or some in other part? its normally cool your refrigerator inside part.If ice is present your fan have insufficient air neede to frost free your evaporator its not the same with the origina you replace,beside your thermostat is not working have check this one.
Nov 23, 2008 | Kenmore 61042 Top Freezer Refrigerator
Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
Oct 04, 2008 | Kenmore Refrigerators
Kenmore refrigerator
i think you will find fan has stopped working - take back plate off inside freezer and check fan goes and that pipework is not iced up
Sep 10, 2008 | Kenmore Refrigerators
Top refrigerator section will not cool
Check the evaporator fan , freezer must have a fan to avoid ice formation, if evaporator does not work, thermic sensor jams up and freezer stop working. The fan is located behind the panel in the freezer.
Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.
This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.
Check also the defrost thermostat, which is on the evaporator inside the freezer.
If it isnt defrosting, change both.
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
140 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
tootsie mason
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
