Question about RCA RCR350 Remote Control
I need to reset the code after changing batteries
  • RCA Master
  • 8,457 Answers
Take out the batteries for couple hours,well rest itself to factory setting.
Posted on Dec 12, 2009
SOURCE:
Need the radio code to reset after battery was disconnected.
Afraid there is no radio code as such....the Saab headunit is paired to the car with Saab Tech 2 software.
A dead battery swap shouldnt lose the radio if it was working before you changed the battery.
Have you checked the fuse for the radio?
You should also post on Saabcentral
Jan 14, 2016 | Saab 95 Cars & Trucks
Abs,tc&brake light stays on after changeing battery
I would disconnect the negative cable on the battery so it can reset the abs module, on these cars when you change the battery you need to have a 12 volt supply connected to your lighter before you disconnect the battery so there will be no reset on any of the modules in this vehicle.. if that don't do the trick you need to scan the abs system to see if you have any hard codes or just to reset it with the scanner.. abs is for antilock brake system and tc is for traction control they both work out of the same module
Jul 19, 2014 | 2005 Buick LeSabre
Change battery on my 2004 honda CRV 2wd i need a code to reset radio
The code is usually on a sticker on the side of your radio or the side of the glove box. sOME TIMES THEY WILL PUT ONE OF THE STICKERS IN YOUR OWNERS MANUAL ALSO
Good Luck
Apr 10, 2012 | 2004 Honda CR-V
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
Jun 22, 2011 | Weiser Lock GED1460X3BR Lifetime Polished...
Why does the change oil light soon keep coming on.
It comes on when the computer recognizes that you need a oil change. In older models, they tend to come on for no reason. If the oil is good and you know it doesn't need changed, don't worry about it. A oil changed is recommended at 3000 miles, but I have always went 5000. You car has a sensor that recognizes the oil command. You might be able to get rid of it by taking off the hot side post of the battery. If your not worried and you know the oil is ok, I wouldn't worry about it. Make sure the cap is on tight though. If you have anymore questions, please let me know. I am here to help. Thanks for choosing FixYa.
Feb 23, 2011 | 1999 Buick Century
I have a 2002 Hyundai Elantra, I changed the battery , now I need the reset code for the CD player HM 5064. I cannot find my manual. Can anybody help?
Normally the Audio (Radio CODE) is noted in the owner's manual. If you don't have it, you must contact Hyundai Motor America and give them the Vehicle VIN number... they may then (possibly) be able to give you the CODE.
Nov 01, 2009 | Hyundai Motor 2002 Elantra
Need to reset electronic safe
i have changed batteries and pressed the reset button but it still wont open any ideas thanks karen
Jul 22, 2009 | Kitchen Appliances - Others
Changed car battery unable to reset radio code...Help!!
ALL at the same time, try again!
Good Luck...
Jun 14, 2009 | 2003 Suzuki Aerio
RCA RCR350 Remote Control Logo
280 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
