Question about Dacor MCS130 Millennia Electric Single Oven
Touch pad works intermittently for light, timer, clock.
JUST CHANGE THE TOUCH PAD
Posted on Jan 28, 2008
Touch pad all lit up on GE 30 " slide in range
locate service manul / wiring diagram comees with all usually convenietly located taped to back inside pannel. shut off breaker , or slide out an unplug, read, manul if present plug back in fallow the set up steps,an trouble shoting. press,bake, set temp,and press start press timer,set timer ,and,press start again.should do it,.if not check for loose wire on oven senser.possible touch pad replacement. worst case. good luck
Feb 22, 2013 | GE Ovens
We have an indicator tone that goes off every minute, but it appears that nothing is set: oven is off, timer is off, clock is set. What is this? What can we do to turn it off?
It sounds like your electronic control is on the verge of dying. Try cutting of the power to the oven via the circuit breaker for at least 10 minutes then turn it back on and reset the clock. If the oven continues to beep something in the control is failing. It also could be the touch pad has a stuck button and usually the only way to repair that is to replace it. You could try powering down the oven and disconnecting the touch pad then power it back up. If the beeping goes away you need to replace the touch pad.
Aug 29, 2011 | Hotpoint Ovens
Oven wont heat up, F-1 on timer
This indicates the ERC Electronic Range Control has failed. First check the key pad. Press each button one at a time. You should feel or hear a click and feel the retraction. If any button is not working the problem is likely in the key pad. If you locate the tech sheet ( somewhere on the stove, usually in the control panel) it may have a ohm check that can be done on the key pad to rule out the key pad. Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control(ERC). If all seems good the control is at fault. Check to see if you have power going into the control. If you do and nothing is working the control board or ERC needs to be replaced. Here is a link for checking and replacing an oven control. If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Oct 22, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
How to set oven timer on a GE electric stove
that is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Aug 28, 2010 | GE JTP20 Electric Single Oven
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Control beeps continuously. Display shows F1. Started when oven had not been used for a long time. Pushing oven and timer off buttons resulted in 10 seconds of silence before beeping resumed. Same for...
Usually, This means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 28, 2009 | GE Ovens
Oven timer keeps going off even though we never set the timer. a code of F1 flashes on the display
HI, this is a defective touch pad/control board failure code. follow the test below to confirm the actual part that will need to be replaced.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Aug 12, 2009 | Jenn-Air Ovens
F1 error/touch panel not working on GE Monogram Dual Oven
Usually, the F1 means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
I recommend a service call for this repair.
Jun 02, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Oven not working Message E0-F2- showing
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Apr 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F7 code on maytag cwb3100aab 24" wall oven.
Hi, The Function key is shorted or stuck.
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Apr 11, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Dacor MCS130 Millennia Electric Single Oven Logo
149 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
