Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
In the past few day i've noticed the picture is
In the past few day i have noticed the picture is not as bright and brillent as it normanly is. i have tried to adjust the settings and it does not solve the problem. could the picture bulb be going bad?
BRIGHTNESS. Your owner's manual probably says that the brightness setting is used to control "brightness" or "picture intensity" or something other fuzzy non-descript term. The truth is that brightness is used to set the BLACK level in the picture.
On most TVs and projectors in use today, brightness is set too high. That's because people think "a bright picture is good, so I will set it as bright as I can get." Well, that's nice in theory, but entirely wrong in practice. Setting the brightness level too high makes a black tuxedo look gray rather than black. It muddies up the shadow areas, and reduces the overall snap and crispness that the picture would have if properly calibrated.
To find the right setting for brightness, go to the image in your movie that has textured blacks and hopefully some shadow/low light areas in which there is detail. Then freeze on that frame. As you move the brightness control down, the intensity of the blacks will increase, and shadows will get darker. As you move the control all the way to zero, you will (hopefully) see that the low light shadow areas will also go to solid black and lose their detail.
The optimum setting for brightness is achieved at just the point where true black objects appear as black as your system will make them while retaining as much visible detail in the shadow areas. Above this point the blacks appear to go grayer. Below this point you lose detail in the shadows. On many video systems, this optimum point is toward the lower end of the brightness scale. But find the point that looks correct to you regardless of where it is on the scale.
CONTRAST. The contrast control is similarly confusing. It is also often set too high on the theory that contrast is good, and therefore we might as well get the most we can out of our set by turning it all the way up. In fact, the contrast setting is used to control the intensity of the brightest highlights in the picture, so it is (oddly enough) the opposite of brightness control.
First, find your test scene in which you find textured whites in bright light, and freeze that frame. You are looking for the brightest elements in the picture in which you want to retain visible detail.
Let's assume you have a whitewashed fence in sunlight. If you start with the contrast set low, the fence will appear light gray rather than white. As you move the contrast control up, the fence will get whiter. Eventually details in the texture of the fence will begin to disappear.
If you continue to push contrast past the optimum point, the wood-grain texture of the fence will go solid white and all visible detail will be obliterated. Push contrast up even a little further, and our fenceposts might actually appear to expand very slightly due to a glow around the edges. This phenomenon, called "blooming" is a definite sign that your contrast setting is overcooking the image (and maybe your picture tube as well—don't ever leave the contrast control set this high!!!)
Find the point at which whites look white while retaining as much texture detail as possible. This is your optimum contrast setting. On most video systems, this setting is toward the higher end of the scale, but it can be anywhere. Find the point that looks correct to you. (By the way, unlike TV's, digital projectors will not bloom)
Now…note the following: brightness and contrast can be to some degree interactive. Your new contrast setting may have affected your brightness. So return to the brightness scene and verify that your blacks are still black, and you still have maximum detail in the shadows. Adjust it if necessary, then return and adjust the contrast setting once again if necessary. (You can see that this is much easier if the black and white elements you are testing all appear in the same image!)
COLOR. The color control on your set determines the level of color intensity in the image. One of the most common errors people make in calibrating their video systems is overdriving the color. That's what makes Larry King look reddish-orange on the TV at the gym. Overdriving color is common because once again, people naturally think, "I want to get as much color as I can out of this color TV, so I will crank it up some to make sure I get the most out of it!" No. Bad mistake.
If you move the color setting down to zero you will notice that your picture will turn into a black and white image. The optimum setting for color is achieved by increasing the setting just to the point where colors look natural and not a bit more! Flesh tones should look natural and without any hint of an unnatural glow. Grass should look naturally green rather than screaming spray-paint green.
When adjusting color, make sure that your test image has relatively unsaturated colors. Flesh tones or natural landscapes are ideal. It is impossible to set color properly if you are using a brilliant red Ferrari as your test subject.
On the large majority of video systems, the optimum setting for color is somewhere near the middle of the scale. However, trust your eyes for the optimum setting and think "what looks like the most natural, accurate reproduction of reality?" Any overdriving of color will make the image look artificial.
TINT or HUE. The tint control adjusts color balance rather than color intensity. It is an easy control to set properly, but for some reason many people don't get it right. When flesh tones look either too green or too magenta, a phenomenon you see with amazing frequency, it is because the tint control is not set properly.
Find a human face and freeze-frame it. (In choosing your test subject, note that lighter skin tones will show errors in tint more readily than darker skin tones). As you move the tint control to one end of the spectrum, the face turns green; as you move it to the other extreme, the face turns magenta (red+blue).
The correct setting for tint is the point near the middle of the scale at which you can detect no hint of either green or magenta. It is the most neutral point between the two extremes. The flesh tone looks the most natural at this point.
SHARPNESS or DETAIL. The final setting is sharpness or detail. Now, pray tell, who in their right mind wouldn't want the sharpest, most detailed picture they could get? And since there is a control that lets you turn it up, why not turn it up? That's what many folks do, and of course it's exactly the wrong thing to do.
The sharpness control adds processed information to the picture that is NOT part of the original video signal. It adds artificially highlighted edges, and makes the picture look less natural than it otherwise would. This is most evident along the continuous edge of a dark object against a middle-toned background. When sharpness is overdriven the dark edge will be outlined by a white ringing effect that increases contrast just along the edge of your dark object. That edge "highlighting" effect is created by the sharpness control. It is an artificial manipulation of the image. It wasn't in the original scene, and it shouldn't be on your screen either.
On most televisions, the optimum setting for sharpness is zero. On many digital projectors, the optimum setting is either in the low or middle part of the scale. Picture tube televisions and digital projectors behave differently in this regard; on a digital projector it is often possible to fuzz the image by setting sharpness too low.
Now look at your picture with the sharpness turned down or off depending on what works best on your system. You will see a smoother, more natural image. It might take some getting used to, since you may be accustomed to viewing video with all the artificial edge enhancements that create the illusion of added sharpness.
However, when the interference and noise from the artificial sharpness enhancer is removed, you are seeing the most genuine reproduction of the video signal that your projector or TV is capable of. And if you view it for a while, you will gain an appreciation for just how smooth, natural, and satisfying the picture can really look.
Posted on Dec 12, 2009
    President:
  • 632 Answers
Yes, the bulb is going out and needs to be replaced. Refer to the user's manual for the lamp type and the replacement procedure. Using a different lamp type will damage your TV. Specify the model of your TV if you do not have the manual to give you the lamp type and the procedure.
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
Jul 19, 2013 | Televison & Video
Dark picture on screen
change your settings from natural to brillent on your tv , note the bulb wont last as long on brillent because of the extra power it takes to run it , try that and see if its what your looking for
Sep 11, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My mtisubishi WD-60735 is not as bright as it use to be. I've tried adjusting the brightness and it dont help
This is an indication that the bulb is already on its peak burning life. You should replace the bulb so that the picture(brightness) will back to normal again....
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 06, 2011 | Mitsubishi WD-60735 Projection Television
T.V. screen is green with bright horizontal lights top to bottom
There are 2 possibilities of green screen in this model.
1- Driver circuit of green gun is defective. 2- Screen itself is defective.
Now I want to know, do you have TV repair experience and basic electronics knowledge to test and check above 2 sections in TV?
Jan 10, 2009 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Dim picture
I would check the 160 volt radial lead capaitors in the high voltage circuit for high ESR or change in capacitence.
Dec 27, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Screen`s brightness less
<Fn> + <→> Brightness up Increases the screen brightness.
<Fn> + <←> Brightness down Decreases the screen brightness
If tese dont work either your LCD lamp or board may be going bad.
Nov 18, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
Pictures taken during the day come out VERY bright, even white
Might be worth flicking through all the settings menus for a few minutes - look in particular to see if you've got it out of Auto into Manual Exposure, or if somebody has accidentally selected a "brighten everything up by a couple of stops" mode. A.
Jun 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Dec 01, 2006 | Toshiba 32A42 32" TV
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
571 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
