Question about Marshall MG100HDFX 100-Watt Amplifier Head
The overdrive does not work at all, it sounds really bad when I turn on the overdrive 1 or 2. How can I fix this?
  • smalley_fred Dec 12, 2009
    Thanks I'll get on it right away.
  • 1,241 Answers
If you have a lot of hours on this amp, You may have some bad grounds. These will need to be resoldered. Inspect the board carefully under a magnyfying glass for rings around transistors that are mounted on heatsinks. The heat sinks are tall aluminum fins that are used to dissapate the high heat from these transistors and ICs. I bet you need to resolder the sound amp IC...has about 7 pins. Also check those capacitors..some may be bulged, peeling, or just plain dry. Find someone who can use a cap checker! These are good starting points. Nothing is completly shorted yet. If it was you would have a blown fuse...but we are trying to prevent this! Good Luck!
Posted on Dec 12, 2009
Alesis Quadraverb Q2. When I turn on Alesis Q2 the programs 1-100 preset are working but when I turn on programs 200-300 user It does not work. There is only "bad program" characters on display.
The Problem is a dead battery which is soldered to the circuit board inside the unit. It's a Panasonic BR-2325-1HC, but really you can replace it with any similar 3V battery.
Here's how I fixed mine.
http://andrewapeterson.com/2013/08/fix-alesis-q2-first-made-strange-sounds-then-bad-program-issue-quadraverb-2-battery/
Feb 07, 2013 | Music
How do I fix a blown op amp on fender hot rod deville 2x12?
Unless the person that analyzed this problem used an oscilloscope and did detailed troubleshooting, I would NOT jump to the conclusion that aan op amp was blown BASED upon my looking at the schematic of the unit. There are MANY components involved with the overdrive channel, including relays and other transistors and components. The most probable caause would be that 1/2 of the V2 vacuum tube is burnt out. Test by swapping V1 with V2. If NOTHING works, then replace the tube that is NOW in V1 as the second section of it has a burnt out heater. Also a bad potentiometer for the OD channel would be a suspect. A VERY common problem is broken solder at pot terminals. Try plugging a set of headphones into the preamp output. See if you can hear sounds in bothe OD and clean channels. Note you will only hear sound in the LEFT headphone as the preamp out is MONO. MOST of the three op amp chips would NOT kill the OD signal if they were bad.
Sep 04, 2012 | Fender Hot Rod Deluxe Guitar Combo...
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
Aug 26, 2011 | Epiphone Les Paul Special II Guitar...
No sound when on overdrive
I am guessing that an IC is at fault. You don't really mean something like "no sound when switching to channel two" do you? If that's the case it could be a defect in a pot such as the volume pot. I have worked on hundreds of Marshall amps over the years. You can email me at computerlen@hotmail.com anytime for help if you want.
Jun 17, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Hi I have a marshall haze15w amp and stack, the problem seems to
There are many models of Marshal amps icluding 15Watt types.
First thing to try is to see if headphones have normal volume. If they do, then the headphone jack switch that connects the speaker is LIKELY bad.
If the headphones do not have any volume, LIKELY causes are:
1. Fried output power amp
2. Volume pot is broken or has bad solder joints to the circuit board.
Jul 10, 2010 | Marshall 15 Watt Guitar Amp
Deville 212 overdrive channel making Loud humming noise
It sounds like a filter capacitor(s) has failed. The electrolytic caps dry out and cease to perform allowing unfiltered power to reach the preamp sections and get amplified.
Being this is tube with high voltages, an experienced person should work on it due to shock danger.
I assume you checked the tubes for shorts as well as emission since a heater to cathode short could cause this as well.
Sep 30, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Looking how to get a more distorted sound but cant find it. any recommendations
If you have 2 "volume controls" such as "vol" and "master vol" or "vol" and "gain", try turning them in opposite directions about 1/8 turn at a time, checking the sound at each increment, then reverse both if no results.
Driving the input a bit harder by turning up your instrument will help some also.
If that does not do enough for you, try a nice distortion pedal like a Boss Overdrive (the yellow one).
Happy harmonics !
Jul 09, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Marshall MG100HDFX 100-Watt Amplifier Head Logo
73 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
