Question about Jenn-Air JDS8850AAS Dual Fuel (Electric and Gas) Kitchen Range
Beeping will not stop on jenn-air oven-remove probe flashes on, but probe is removed.
  • 106 Answers
Your probe socket may be shorted or wires going to it grounded to frame. Or your main computer board is NG.
Posted on Dec 12, 2009
2 Suggested Answers
  • 409 Answers
SOURCE: remove probe from oven
most electric ovens have a temperature sensing probe inside of them. this is to prevent the oven from overheating and causing a fire. the reason why it's asking you to do that is because it's either dislogged from its place or it need to be replaced.
Posted on Sep 13, 2008
Keeps beeping saying remove probe from oven on the screen.
Something must have sprayed into the probe connection and making contact. Since it is smaller than a Q-tip you will have to try a wood toothpick to clean it out.
Jul 16, 2011 | Jenn-Air Ovens
My probe (PRB) keeps flashing and beeping, how do I make it stop? Thanks!
Hello, Thank You for using FixYa. I will be helping you today.I just had a service call on this issue. If the probe receptacle is clean you may have to replace the control. Try turning off the power for five minutes and see if that works.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
My Jenn Air oven is asking me to remove the meat probe. The only thing I did before it asked me to do that was to turn it try to preheat the oven to 350 degrees
you could have a bad probe receptacle. Or a board problem. Kill power to oven, wait 10 min, cross your fingers and restore power.
Oct 26, 2009 | Jenn-Air Ovens
Front control panel shows "Remove Probe From Oven" & Beeps.
I have the issue as well, seems like when I use the convect. feature. I have not called to have it serviced yet, but I have found that opening the oven door and truning the fan on for a few minutes, corrects it. At least until you turn it off again.
Sep 23, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Remove probe from oven
Sep 13, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Kichenaid electric stove
the probe is put into the oven to sense heat and to prevent the oven from oveheating during normal operation. the reason the probe is beeping is because it's dislogged or needs to be replaced.
the only way to make the beeping stop is to disable it but i wouldn't recommend it.
have a technician run a diagnostic on the stove. sounds like the probe needs to be replaced.
Jul 09, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-air probe won't shut off
mine did the same thing kept beeping and flashing prb, solution was it was mounted very close to the frame of wall and house must of shifted causing the wires on the outside to make contact with each other. adjusted the unit and beeping stopped .
Dec 23, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JDS8850AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
1,554 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
