Humidifier solenoid valve kicks in and out making a loud banging noice. Humidistate was replaced and problem remained. Do we need to replace the solenoid valve?
Thank you for your help.
Virginia
I was getting a loud "clunk" when the solenoid turned on. By reducing the water input from a full stream to a trickle, pressure to the solenoid was reduced and the "clunk" became an a barely audible "tick" sound.
If the valve noise is excessive, or more than it was originally, then yes, replace the valve.
If the noise is no worse than it was originally, then you may be overly sensitive to the noise its making.
Also, check that the valve has not shifted slightly in such a way that it's opening and closing rattles it against something that it didn't used to rattle against. A sheet metal panel will amplify the valve opening and closing.
Let me know what you find.
