Question about Sony KP-51WS500 51" Rear Projection Television
Green line through the picture - Sony KP-51WS500 51" Rear Projection Television
  • Sony Master
  • 8,457 Answers
Ur convergence is dead,U know how to solders?Tries these websites. Tv repairWorld.com,Tvrepairkits.com.For the convergence kit.
Posted on Dec 12, 2009
SOURCE:
How do i get the green lines out of pictures
Camera from 2008. Display broken. Needs replacement. Not worth it. Sorry.
May 16, 2014 | Olympus FE-320 Digital Camera
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
I get green horizontal lines
Are the green lines on the camera while viewing the picture or is it in the pictures once you have saved them on the computer.
Green Line on your view is you LCD. If the pictures comes out alright then it is just bothersome. Good Luck
Jan 07, 2011 | Fuji FinePix S9000 Zoom Digital Camera
I have a green line in my picture. The picture is distorted some
Press the menu button on the tv if the tv still ahs the green line the tv needs repair. If there is no green line through the menu try a second source, a dvd player or a game system. If the issue only is with the original source, replace the original source.
May 06, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Green line in middle of tv when switched on
Is there a picture with the green line going through the centre. If it`s just a green line with no picture, it sounds like the Frame (Vertical scan) Output IC has failed and possibly the safety feed resistor near the LOPTX. The reason why it`s a green line is to protect the tube from phosphor damage. The older TV`s would produce a VERY bright white line across the screen which could burn the phosphors withing the tube if left turned on in that condition. It`s not an expensive repair, but is it worth it with the price of Modern TV`s nowadays. If there is a picture with a green line, it may be due to phosphor damage, in which case, it`s a new CRT (tube). Ian
Jul 15, 2009 | Panasonic Televison & Video
Wavy green lines when picture is black
Check out this site. These TV's are known for the CRT's going bad. This site shows how to make adjustments that could help extend the life of your set. Take a look at the first picture, if the lines look like the ones in the picture this site "should" help. The picture shows a problem with the red but don't worry about the color, look at the lines. I hope this helps.
Mar 22, 2009 | Sony KP-57HW40 57" Rear Projection...
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Sony KP-51WS500 51" Rear Projection Television Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
