Diagonal snow has developed on the screen lately. We have a digital cable box, but calling for a signal boost doesn't help. Is the TV going bad, or the cable box?
  • Televison & ... Master
  • 1,229 Answers
You can almost guess that the problem is a bad ground on your coaxial cord. A very very common problem. You may have to many connections...a vcr,DVD player, a video game box etc. all connected to the tv and cable box. Make sure everything is tight and then remove one of the aux video connections to see if you cet a clear picture. The best connections are the ones that twist on...the slide in coaxials are not always the best. You may also need new coaxial cables too! Good Luck!
Posted on Dec 12, 2009
  • matt martin
    matt martin Dec 12, 2009
Sharp 20 flat screen TV
if you go through a cable box, the box has to be reset or its bad.If it has a cable box, unplug from back of box and plug back in after 60 seconds and see if this works. Some boxes will count down to reset them
Sep 14, 2016 | Sharp Televison & Video
Scrolling diagonal lines
The cable box signal on the components video have a too high refresh rate frequency, that is the reason for the lines.
Use RCA cables or an alternative connection.
Other solution is changing the display out settings for cable box (from PAL to NTSC etc.)
Sep 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
My dynex lcd tv keeps saying no signal when cable is plugged in?
It sounds like the CATV portion of the TV tuner is bad--Cable band.
You may have an option---with a cable box that has the audio/video jacks for output of signal on its rear side connect to a unused video input on rear of set--go to that input and change channel via the box---BY PASS THE TUNER IN THE SET THIS WAY.
May 25, 2012 | Dynex Televison & Video
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
Tv getting snow & static sounds on all channels.
This TV, I believe, does not have a digital tuner. If you're trying to pick up channels off the air with rabbit ears or a rooftop antenna, you'll need a digital converter box. Without one, there aren't any channels for it to tune in, so all you'll get is snow and static.
If you have a converter, or are using this TV with a cable box, satellite receiver or a similar device, you may have a bad connecting cable. Be sure the cable is firmly connected and that the center pin isn't bent or too short for a good contact. It should extend an eighth of an or so past the end of the connector. Try another cable.
If this set has been working properly and the trouble is new, something is up with the tuner. It may have been damaged during a storm or from power line problems. Poor solder connections may have developed on the circuit board. Other electronic failures may have occurred. If the trouble appears to be inside the TV, it's probably not worth repairing. The replacement cost of a small TV would be not much more (if not even less!) than the labor and parts to fix it.
I hope this has helped. if so, please take a moment to give a thoughtful rating. Thanks for using Fixya!
Oct 22, 2010 | Craig CTV-41331 13" TV
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
The picture seems very coarse and has diamonds running across it
Hello: In standard defintion the picture is showing in 480p which is the lowest resolution for LCD televisions, The picture will only look as good as the signal its getting, If you have cable then it should look some what better even with std defintion. The Diamonds/triangles are caused from a weak digital signal or weak broadcast station. This is a normal occurance for LCD televisions as the picture is put on the screen in blocks. I would not say your television is bad, just a poor or weak signal, If you are using a digital antenna and not cable, then you might try purchasing a signal amplifier to boost the signal before going into the set.
Nov 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Sansui 42" Plasma
First we have find out if it's the set or the signal, So does this tv have snow on all inputs or just on cable? if just the cable try a another tv in its spot, if the problem continue mabe a call to the cable company is in order, I know that many cable problems come from bad conections or loosing a grounding point were the cable enters the house, Now if the problem shows up when watching a DVD or other video source it may be the tv's fault. Most likley a voltage is droping and need to be repaired perty quickly. What some people see as snow we see as a low VA voltage that is putting stress on a control board
Feb 13, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
"No signal"
It could be a bad barrel at he TV and at the wall. Your cables and connector could be of poor quality. You may also have a signal issue. Has anyone fron the cable company be out to take a signal reading?
Nov 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
