hi,please cheque printer papper jam & please take the jamed papper after printer is turn on to contiue see the error please replace the high voltage power supply
first check your toner cartridge. some time your toner cartridge is damage then black print out is coming.
then check your machine printer and faxes ,check print pages status.sometime their have early print outs.
didnt solve your problem you have to replace main board
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Just remove the ink cartridge from the printer and clean the surface contact using a cotton moistened dipped in an alcohol . Return back the cartridge and try to print again.
Try also to Press and Hold the STOP/RESET button until printer restart. Release the button when to completely initialize the printer
There is a little white tab on the left hand side of the papper tray. If it dose not pop up the papper when the tray is closed, you will get a papper error,.
Yes definetly,
First cheak that paper was cuts wrincled from any side from top or bottom, after pulling if yes cheak that the
small part of papper jam in to the papper path or sensor earia
or papper feed out sensor actuater arm jam by pulling the papper by you after cheaking those things you will able to solve the problem you are facing,
vyas
