Question about Sony PlayStation® 3 (60 GB) Console
My controller keeps shutting down and doesn't want to charge why
  • 102 Answers
If it is an older controller, that batteries inside maybe worn out and not hold a charge anymore, you will most likely have to buy a new controller for it. so the lights on the controller still flash when plugged into the ps3?
Posted on Dec 12, 2009
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
My 2011 Sonata cruise control stops working going down steep hills. The set light goes off. I had it set at 50mph but applied brakes when it increased to 70mph. Dealership says they can find nothing...
going down steep hills will all but over ride a cruise control, since the motor is trying to keep the vehicle slowed to what your desired speed that you set , unfortunately this doesn't always work,, as your speed increases, the motor can't keep the speed reduced, when you apply the brakes, the system shuts off, cruise controls were meant to be used pretty much on long flat surfaces with Low inclines ,,
Aug 25, 2011 | Hyundai Motor 2004 Sonata
2002 mercury montaineer , battery light comes on , they gages shut down couple minutes after then the truck acts like it gonna shut off....when getting a jump, the truck fires right up, couple minutes...
Your battery is definitely low. First clean the terminals on the battery and the inside of the terminal rings on the wires. If you have a slow charger put it on that overnight and see if it holds a charge. If it still keeps depleting or doesn't charge overnight then either your battery or your alternator are done....possibly both. So take the battery to have it load tested. Most places that sell them can test them. If the battery is done replace it then test the battery with a volt meter. If the old battery is still good put it back in the vehicle and test the voltage with a volt meter. With the engine off the voltage should read 12 volts (once its fully charged or if its new) with the engine running it should read around 14 volts. If it is way higher than that or it doesn't go up at all your alternator requires replacing. Alternators are fairly easy to replace but if you don't feel comfortable with that take it in to a mechanic.
Jul 25, 2011 | 2002 Mercury Mountaineer
It keeps running and doesn't shut down. Freezer
Check condensor for clogged coils and make sure the back is on it. (The pasteboard covering over the Service Opening on Bottom Rear)
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 17, 2011 | Whirlpool Refrigerators
Started flashing on charger and then shut down now will not charge or come on
If your Harmony remote is not charging on the base, try pressing down on the remote, and wiggling it around. It's just that the pins are not making contact.
If pressing down helps, you can fasten it on with a elasitc band or something so that it keeps charging. Also, if it is still under warranty, I woul advise contacting Logitech's wonderful support team to get replaced.
Hope that helps!
Dec 18, 2009 | Logitech Harmony 890 LCD Remote Control
My sansa willo not charge. It keeps shutting down
try checking every five minutes and turn it on.
Sep 29, 2009 | SanDisk Sansa e250 MP3 Player
My Zen Keeps Shutting off even though it is charged, I turnit on and when I press play it shuts down
my mp3 player keeps shutting down after 10 minutes of play even thought the battery is charged
Oct 06, 2008 | Audio Players & Recorders
Sony PlayStation® 3 (60 GB) Console Logo
87 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
john o grady
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
