Question about Gateway GT5432 Refurbished AMD Desktop Computer - AMD Athlon 64 X2 5000+ 2.6GHz , 1GB DDR...
USB Ports I have no USB ports working on my other Gateway computer. Can you help me fix that please? Started having problems on Wed with a couple ports and now none are working. I cannot do anything without at least my mouse right?? Thank you for any help. Terri
  • Anonymous Mar 31, 2014
    The top mounted USB ports and data card ports do not work. The USB ports have power, but are not recognized by Win. 2007. The USB slots in the back of the computer do work.
  • 48 Answers
One way would be to download and install latest device drivers from the net. it should help.. if you are using win XP, there is likely a BIOS or Windows configuration problem. On some computers there is a configuration option in the BIOS that asks whether an IRQ should be assigned to USB. Although the option's actual wording varies among BIOS manufacturers, you must enable this option by setting it to either On or Yes (depending on your BIOS manufacturer and BIOS version). Otherwise no USB devices will work on XP. A problem with Windows XP’s USB Controller configuration can also prevent any USB devices from working. To determine whether the USB controllers are working properly, open Device Manager and expand the Universal Serial Bus Controllers node. Beneath this node, you should see a USB Universal Host Controller and a USB Root Hub. Depending on your PC, there will either be a USB Universal Host Controller and a USB Root Hub listed for each of your computer’s USB ports or a USB Universal Host Controller and USB Root Hub for multiple ports
Posted on Jan 20, 2008
  • Faizan Shah Ahmad
    Faizan Shah Ahmad Dec 10, 2013
    but I`m facing this problem in windows 7 and it shows that "the usb is malfunctioned or not recognized"
Kokaso m1050s
I have had a similar problem with a computer, where usb ports would sometimes work fine, then suddenly become erratic. It wasn't until I replaced the computer, new computer, new operating system, new software, and while transfering files over the same thing started happening again - odd!
It turned out to be a white sd / camera card reader which was plugged into a usb port, unplugged it and all was normal again. I would not have guessed a card reader could have upset all the usb ports, but it sure did!
Or, in your case, if it is just one port, perhaps it is not connected to the motherboard.
Jun 14, 2013 | Kitchen Ranges
The 2 right (monitor's right) usb ports are not working, is there a fix
did you attach the usb cable from the computer to the monitor, needs this for powering the usb ports and to transfer data to the computer?
Dec 14, 2010 | Gateway FPD2275W LCD Monitor
I have 4 usb ports 1.0 I am not able to download
The port in the PC needs to be USB 2.0 standard.
A quick analogy. Think of a tap with 1/2" outlet, and you connect an adapter and a 1" hose to it. It will work, but you will not get more water just because you attached a thicker hose; the original outlet has to have higher diameter to give you more water.
If all your USB ports are 1.0 version, the only option is to purchase an USB 2.0 PCI card mounted inside the computer - this will give you 2 or 4 (depending on card model) USB 2.0 outlets.
Please come back with a rating/testimonial if helped.
Jul 12, 2010 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Damaged USB Port
Ok I think the best method to "Fix" this would be to get your self a 4 - 5 port USB card, they are, real cheap, insert it into a spare slot, inside your PC, and install the drivers, if any, and use that one. And simply ignore the other one all together.
Feb 18, 2010 | Gateway Essential 400 PC Desktop
Usb ports not working
buy a new mother board or use recovery media after saving files and clean out usb ports
Jun 13, 2009 | HP Pavilion dv9000z Notebook
Gateway gt4010 usb ports are all failing.
It's your hard drive going bad! I had the same problem in my company. Could not figure it out but when i flopped the hard drives they started working agian.
Mar 26, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway M320 USB Ports Stopped Working
Just in case, Microsoft has a downloadable fix-it for non-responsive USB ports. Not sure if this will help, but might be worth a shot. Scroll all the way down to the bottom of the page for the download button:
http://support.microsoft.com/kb/817900
Feb 13, 2009 | Gateway M320CS Notebook
Gateway USB ports stopped working
So maybe you need to install the drivers for the USB device you are trying to connect. Also, with the computer off, try cleaning all USB ports and plugs. You can buy electrical cleaner in a spray can at Radio Shack. Let it dry thoroughly before powering up. But to me it sounds like a driver problem. Unless maybe your USB BUS is going bad.
Jan 06, 2009 | Computers & Internet
2 of 4 USB Ports Not Functioning
Most likely a motherboard problem, though you can try and re-do windows, best bet on getting it all to work is Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Though this might really get on your nerves having to do this multiple times, id get a new motherboard.
Dec 26, 2008 | Gateway 4540GZ Notebook
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Gateway GT5432 Refurbished AMD Desktop Computer - AMD Athlon 64 X2 5000+ 2.6GHz , 1GB DDR... Logo
206 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
