Question about Maytag LAT3600A Top Load Washer
My washer leaks and we checked the pumps and hoses. Pumps and hoses are fine. The leak seem to be coming from the top portion of the washer during agitation and spinning. Thanks Lian
    President:
  • 1,214 Answers
Sounds like p/n 22001299, tub cover and gasket assembly, if it's leaking from the top or upper part of the washer tub. It could also be the bleach hose or air vent hose as well.
Unplug the unit from power, pop the top and look for water tracks down the side of the drum.
Or p/n 22002417 seal, which is at the top center of the drive shaft.
Let me know what you find.
Posted on Dec 12, 2009
Roper Washer is leaking at the base, It appears to be coming from the water pump.
Its not uncommon for these drain pumps to leak fortunately the are very easy to replace. Place a small pan under pump remove both hoses and then pop off the retaining clips and pull the pump forward. line up the new pumps drive slot with the drive shaft coming off the motor reinstall retaining clips and hoses Good Luck
Nov 14, 2010 | Roper RAS8445KQ Top Load Washer
Washer seems to be leaking during spin cycle.
If the water is gushing from the washer, check the small plastic air dome hose on the lower right hand side of the wash tub. Sometimes the hose can come loose and come off. This will cause the water to begin pouring out of the bottom of the the washer when it begins to fill. The following link has some other things you may consider as well:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak.
Another common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
May 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking from washer
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only During drain and spin only All the time During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make
Jan 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Maytag washer is leaking during fill up. The hoses are fine. The leak is coming from under the washer.
The water pump recirculates water during the wash cycle and pumps it out for the spin cycle. Some washers use the recirculation to mix and distribute add-ins like bleach or fabric softener. In some models the spin cycle starts while the water is still in the tub; others drain first before the spin cycle starts.
For the the initial filling of the tub, the pump is not involved. Filling the tub is the job of the water inlet valve. The rinse cycle is also done with fresh water supplied by the inlet valve, although the water pump may be running simultaneously to remove the water while it is being added.
There are two types of pumps; direct drive and belt drive. The direct drive is mounted directly to the motor, the belt drive is mounted to the chassis. The direct drive style can be opened for complete inspection while belt drive models may or may not be designed to be opened. You can however, still remove the hoses and inspect the ports for a blockage or loose connections that may be causing a leak. Inspecting the pump is fairly easy to do, but you will most likely have to open the washer's cabinet.
Typically one of three problems occur with the pump. The first is a blockage in the pump, often from small items like a sock. The second possibility is that the impeller blades become broken or worn down and cannot move water efficiently. Next, in belt drive models, if the belt is loose or broken it does not turn the pump. Finally, Your pump may leak if there is a loose hose or cracked pump housing.In this case, it must be replaced.
Locate the pump, it will have two, three or four hoses. Label each hose and where it connects. The hoses should each have a wire clamp or a hose clamp with a screw. Pinch the wire tabs together with pliers and wiggle the clamp farther up the hose. Screw style hose clamps are simply loosened by turning the screw, then slide the clamp up the hose. Now remove the hose from the port.
Direct drive pumps have metal clips that hold the cover plate unto the pump assembly. Use a screwdriver to pry up the clips and remove the cover. Pull off the pump's impeller unit and inspect for damage.
Belt drive pumps vary and may or may not be designed to open for repair. Examine the pump to determine whether it can be opened. If it cannot be opened, look into the ports for any blockage.
If there are no blockages, the actual leak may be in a damaged hose or pump housing may be compromised. check all hoses for good connections and good hose integrity. if the hoses are not leaking, replace the pump.
Oct 28, 2009 | Maytag MAT13MN Top Load Washer
Kenmore 70 series is leaking water. Could it be the pump?
It depends on WHERE the leak is coming from. If the leak is coming from the FRONT area of the washer, the drain pump or drain hoses are suspect. If the leak is coming from the REAR of the washer, the water inlet hoses, water inlet valve, or dispenser hoses may be suspect. If the leak is coming from under the CENTER portion of the wash tub, the tub seal or wash tub may be suspect.
The first step is to remove the exterior washer case to gain access to view. The following link explains how to replace a water pump (if required) on your washer, but also includes all the steps necessary to access the washer interior:
http://www.fixya.com/support/r397092-replacing_water_pump
Allow the washer to fill about 1/3 of the way and turn it off before unplugging and removing the washer casing. The washer will not run once you disconnect the lid switch connector, so you will need some water in the tub to see where the leak may be coming from.
NOTE: If the problem IS a leaking pump, these pumps are not serviceable and will need to replaced.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Jul 09, 2009 | Kenmore 24032\24036 Top Load Washer
I have a twenty year old Maytag washing machine that is leaking water out of the bottom of the machine. I have checked the hoses and it is not coming from there. Any ideas
hello. i can help you. unfortunately, your problem has numerous possible causes.
During fill only
All the time
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jul 02, 2009 | Washing Machines
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Top load kenmore 110
This is commonly caused by a leaking water pump, or the hoses attached to the pump. The following link explains how to access the interior of the washer to inspect for leaks:
This link explains how to replace the water pump if that is the case. Keep in mind, these pumps are sealed units and are not serviceable. If the pump is leaking, or not functioning, it needs to be replaced. in addition, double check all hose connections to the pump (there usually two hoses) and make sure there are no cracks or holes. Make sure the hose clamps are secured properly. I hope this helps you. Let me know if you require additional assistance.
Oct 21, 2008 | Kenmore 22422 Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Leaking
The pumps usually have rubber hoses fitted them and they can deteriorate over time, moreso around the clamps that hold them onto the pump. Also, maybe the pump has been slightly opened via a worn seal. Either way, there may be a risk of fire if any water gets onto the electrical connections of the pump or spray onto any other open electrical connection inside the machine. It would certainly be advisable to have it checked with some urgency.
During the final rinse and spin, I would think the pump may not be used during these cycles.
Hope this helps somewhat.
Sep 14, 2008 | Whirlpool WTW6400SW Top Load Washer
Maytag LAT3600A Top Load Washer Logo
145 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
