Question about HP LaserJet 5mp Printer
Paper won't pick up from bypass - HP LaserJet 5mp Printer
  • 35 Answers
Service your printer or change pic up roller.
Posted on Dec 12, 2009
SOURCE:
Bypass feed
this is set by the computers driver
or its detecting no paper in the main drawers
Jan 10, 2015 | Toshiba e-Studio 350 Copier
How should i solve my printer it say manual paper empty
it sounds to me that your paper size is not correct so it is tring to pick from the bypass. put paper in the bypass until that job is over or delete that print job. make sure your paper cassette is set to the right paper size. most of the time this problem comes up when rinting pdf files or from the internet.
Oct 23, 2014 | Samsung SCX4623F Laser All-in-One Printer
Paper feed does not pick up properly
Clean the tray paper feed roller rubber,or try using the bypass tray(manual alimentation).
Apr 22, 2013 | Samsung SCX-4521 All-In-One Laser Printer
How do I print labels, envelopes or any non statement size item? Have tried using bypass and all I get is an error message. I had the people where we bought the machine come back and see if they could get...
Hi, wich kind of error message?
Is it " check paper size" or " paper jam" or ...
Does the paper goes all the way trough copier or jams at bypass, at drum or fixing section,...
Did you "tell" over pc drivers that you are want to print on labels, that the lables are eg. A4, that pick up paper from bypass,...
It could also be a problem in pick up clutch and solenoid, or it just needs to clean the bypass pickup roller,...
Send more info
Jun 09, 2010 | Canon imageRUNNER 1023iF Black and White...
1320 HP Laserjet Still Won't Pick Up Paper
Please check limiters paper in tray 2 to be on A4, letter, depending on paper format. Otherwise you have problems with taking the sheet from tray 2.
Oct 09, 2009 | HP LaserJet 1320 Printer
Will not pick up paper from tray. Red light blinks indicating a paper jam. Prints fine if single sheet thru bypass slot.
Not picking up paper indicates either a worn nip roller (rubber on feed spindle) or you have a broken gear in the feed mechanism.
Aug 14, 2009 | Brother HL-2040 Laser Printer
Xerox 7132 noise when picking up paper from bypass
there is either paper stuck around a roller (3) that feeds the paper or you have a bad clutch, most mnfs use magnetic clutches at the rear of the machine or bypass that get a red rusty dust in them causing squeal. recommend xerox takes a look...sorry they are quite expensive hourly
Aug 04, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Print to bypass
Before printing click the property button, go to papar tab, under tray select, change from auto select to by pass tray
May 19, 2009 | Sharp MX-2700N Color Copier
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
HP LaserJet 5mp Printer Logo
48 people viewed this question
Clive
Clive
Thomas F. Schneider
