Question about Kenwood VR-410 Receiver
Kenwood VR-410 Reciever cuts out at high volume
  • 3 Answers
I am willing to bet that you still have factory speakers in the car. They are prob 2 ohm. Most all aftermarket stereos are set up to run 4ohm. and what happens is the internal amp shuts down to keep from blowing the stereo. Check the ohm of the stock spakers and replace them with a new set. You can get them all day long at places like walmart the have sony and others. Or just get them from ebay, What ever works for you.
Posted on Feb 27, 2010
    Scholar:
  • 52 Answers
Very possibly a problem with overdriving the speakers and the breaker inside the receiver is "popping" in order to protect the outputs from being fried. check the ohm rating of the receiver to the speakers and lok for damage to any of your speaker wires. also make sure the wires are not crossed or touching in the back connections to the equiptment.
Posted on Dec 12, 2009
How to conect tv to reciever
how to connect tv to kenwood reciever vr-209?
Jan 22, 2012 | Kenwood VR-209 Receiver
Hi, i have a kenwood VR-506 reciever. I was useing it when it cut out, the same as if two speaker wires were touching each other. Now everytime i turn it on it comes on, but when it cuts in it cuts out...
As long as it doesn't blow any fuses, check the solder connections around the output stage. Sometimes they heat-up and become cold connections - re-apply solder by heating thoroughly to repair the junction.
Nov 01, 2010 | Kenwood VR-506 Receiver
It's a Kenwood VR-4080 the reciever turns on and works but has very low volume and amp sinks get hot reguardless of volume setting?
heat in amps =power or fault, since you have no power then its most likely the fault that is causing the heat, I would take it to my dealer or a good tech. Modern amps like these are very complicated, almost impossible to diagnose and repair without cct diagrams and service info. They also have potentially dangerous DC power rails.
Hope this helps
Thanks for using FixYa
Aug 13, 2010 | Kenwood VR-4080B Receiver
Low volume
Most of the newer receivers do not have PHONO inputs. You would have to use external pre-amp with the turntable.
Dec 24, 2009 | Kenwood VR-606 Receiver
I have a vr 309 kenwood reciever with a bad subwoofer port because sub doesnt produce sound through it but does through another reciever, is there a fuse or capacitor just for this output i can check or...
Are you sure the VR309 is sending a signal out through the sub port? Attach one of your other speakers to it as a test (low volume). Then get back to us.
There are such things as user settings that affect this.
Dec 05, 2009 | Kenwood VR-309
KENWOOD VR-507 RECIEVER
No, take the battery out and bring it to an auto part store and they can test it.
Jun 18, 2008 | Kenwood VR-507 Receiver
Shuts down at high volume
If you have your reciever in an entertainment center that is enclosed or a tight fit for the reciever you need to remove it and put it on top of the center. I have a VR407 and it was doing the same thing. This keeps your unit much cooler and the overheat relay will not turn it off. also I found it much easier to add or wire components much easier.
Steve T. PA
Nov 25, 2007 | Kenwood VR-407 Receiver
Kenwood VR-410 Receiver Logo
314 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
rigger094
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
