Question about Cakewalk Computers & Internet
Hey guys. ''Unable to create new audio file for recording.'' any idea what it is? Sonar 8.5 32 or 64bit, in Windows 7 64bit, 4gb ram ddr3 1333mhz, intel core i5 2.6, m-audio delta 1010lt latest drivers. Happens when i hit PLAY or REC if any track is record-enabled. Tried changing driver mode, diskrecbuffersize, delta asio buffer, read and write cache, deleting picture cache folder contents, and a lot of other useless tweaks. Thanks
4 Suggested Answers
ridik
  • 53 Answers
SOURCE: unable to play downloaded video album with .nms extension
Hi try with this http://www.brothersoft.com/utilities/system_utilities/dvs-nms_3334.html
Posted on Sep 13, 2007
SOURCE: Sonar 6 Producer - palyback quality issue
I had this problem today whilst installing Sonar on my new laptop. It wasn't the click track. It was the playback glitching, clicking and rattling. I put the buffer size to maximium but it was still happening.
I got round it by downloading the latest version of ASIO4all (2.9 beta4) and installing it. I then opened Sonar 6, options, audio, advanced, then selecting ASIO in the driver mode drop down box. Then I closed Sonar and reopened it.
If you use one device for recording and playback it should work now but if like me you use seperate devices or if it doesn't work click, options, audio, general, ASIO panel, advanced options. Here you can select your inputs and outputs. Play around a bit here. Mine worked when the output of the playback device was selected and both the input and output of the recording device was selected.
ASIO4all sorted out my latency issues as well.
Hope it helped.
Posted on Oct 05, 2008
  • 17 Answers
SOURCE: me and some buddies record
Sounds like what is called a latency problem. You need to go into the settings in Sonar and under audio, adjust the Latency to a higher number...I don't know sonar home studio, or I would tell you the exact area to go in the menu's to adjust latency..Hope this helps!
Posted on Mar 06, 2009
I have a SIMS Model SVR-S825 DVR. Can I recover files that were deleted? I noticed that I left the recorder on and it maxed out the memory, this also ran down the battery. Upon replacing the batteries...
Uh-oh.
As new recordings were done then very unlikely that recovery is possible. As the digital files are stored on RAM inside the DVR I think that an app like Power Recovery may work, but never tried PR on a DVR myself.
If it does work, as with a deleted flash-drive, it will try to recover RAW data, and where it can still read headers, creates or suggests a filename extension. Of course, if the stored data is non-windows, then probably wont be readable or recoverable.
Nov 23, 2017 | Sims SVR-S825 Handheld Digital Voice...
Setup pc for audio recording
Records at the highest bit-rate you can (320 is the best for CD audio), keep the gain at a medium setting (too high creates clipping, too low will drive you crazy with volume), and try to set at minimum dual channel (stereo). You may have pre-set options for this, most are dependant on what you want to output.
If size-of-file is an issue, simply decrease the bitrate, but leave all the other settings the same!
Hope this helps!
-- RT
Sep 03, 2009 | Dell Dimension 8300 PC Desktop
Olympus DW 90 VN series. I have been using the
get switch audio converter software from www.nch.com.au
works for us like a charm
Aug 30, 2009 | Olympus VN-4100PC Digital Voice Recorder
Timing after recording. and midi composing
May I suggest you try to adjust your audio settings inside Sonar. Also it is a good idea to always keep your C drive well defragmented. I once had this problem using Sonar LE and the only way I got rid of it was after formatting my C drive and reinstalling the drivers and Sonar again. After that the problem came back and then I upgraded from the SB Live to Audigy SE.
Make sure you also have lots of free space on your C drive and have a decnt amount of ram.
May 11, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
Mar 21, 2009 | Olympus VN-4100PC Digital Voice Recorder
Drivers Disappear
Its a fight between 64 and 32 bit versions. Audio codec is not so compactable with your sound card sysaudio file You need an updated driver which is compact-able with direct x latest can solve your problem
Jun 19, 2008 | Compaq Presario 700 470024-192 Notebook
Hope it helped.
Mar 12, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Canecting US122 with Sonar HS4
Hey there,
Try the latest US-122 driver (3.4.0), you can get it here:
http://www.pcmusic.org/software/version.php/lang/en/id/10422/
There might be a latency problem with the Asio4all driver too, try the US-122 16bit or 24bit driver, they are actually Asio drivers.
Also navigate to Windows Control Panel and make sure that a Windows Media Player Update hasn't minimised the Wave Control Sound.
Good Luck and have fun
Chris (ziraffa)
Mar 02, 2008 | Tascam US-122 USB Audio/MIDI Interface...
SONAR LE NO AUDIO
Microsoft re-engineered the audio bus for Windows. HD Audio is hardware specific, in the sense that specific drivers have to be written to make a piece of hardware compatible with it. Roland is not writing a driver for the UA 25 because they want you to buy an UA 25EX. Get my drift? The UA 25 uses Kernel Streaming, the old way, which exists in parallel, sort of, with the HD Audio bus. But the new ways are always prioritized over the old ways in software, so there is bus contention (glitching).
To fix this there are a few things you can try:
1) Roll back to SP2. SP3 implements the HD Audio bus, so don't use that implementation. If your laptop has an HD audio sound card then I doubt it would work, but your UA 25 would.
2) Try ASIO 4 ALL. This fixed everything but glitching in VST instruments.
3) Reduce the amount of stuff your computer is doing. Optimize your OS by turning off the cute shaded windows and desktops and various processes that you don't need to see or use. There are sites for this. This increases available RAM, CPU time, etc.
4) Video hardware acceleration, sometimes, would fix bugs in software left in by not so clever programmers.
4) You can always just give-up and go along with the bastards and buy new stuff and toss the old stuff.
-SQA MGR
Sep 04, 2007 | Edirol UA-25 External Sound System
Problem with stability
Celeron CPU's will struggle with making music and limit what you can do with audio. Celerons are ok to play music but nor really for making music. Firewire is a better option for making music as it's really fast unlike USB. An option would be to get a faster CPU and try the soundcard again. But i would not use USB audio and would use an Audiophile 2496 soundcard as they are really cheap. Also midi is data and not audio, midi just works virtual instruments and is able to control keyboards through midi out. But first try a better CPU as a celeron isant that good for makign music. I know becouse i've been there done that and go really upset with the same problems your having at the moment. I played the midi files on cuabse and recorded it onto an audio chanel.
Aug 29, 2006 | Edirol UA-4FX External Sound System
Computers & Internet Logo
124 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
