Question about Kenmore Washing Machines
Spin cycle doesn't start
I know its the switch that the lid triggers when its closed... how do i open the top to get to it?
  • feellucki Dec 12, 2009
    THANKS ! JUST CRACKED AND SEE THE GOLD CLIPS TO DISENGAGE THE TOP !
    much appreciated..... now i can finish washing my labradors bedding !
    jeff
    great ! good job ! i got it open . thanks
  • 10,515 Answers
There are 2 screws that secure the console to the cabinet top. The are located in the front or rear corners, and on a Kenmore, may be hidden behind the end caps. Remove the screws, and tilt the cabinet backwards. Remove the 2 gold clips, and disconnect the wiring harness. Tilt the cabinet forward, and off of the base. The lid switch can now be accessed from inside the cabinet (I sit inside).
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2009
Top load will not spin
Have you checked to see if the lid switch is functioning properly. When you close the lid the switch is activated so that the machine knows the lid is closed and can start the spin cycle. If this switch fails, the machine will not spin.
Sep 08, 2015 | Washing Machines
Whirpool washer LSN1000JQ1 topload won't drain .
check the lid switch,open the lid,stick a screw driver into the hole where the strike on the lid closes into,you should hear a clicking sound,no click the lid switch is bad,or close the lid and open it up a few inches and close it down,no clicking sound the switch is bad.you can watch this video and it will show you how to change the switch
http://www.youtube.com/watch?v=V5aW9WkTFhEif the part number is 3949247 and the lid switch is around 50 dollars,common problem.if you hear the switch click when you stick the screw driver into the hole set the timer to spin,pull out the timer knob and then stick the screw driver into the hole again,if the switch is engaging it will drain and spin but if it doesn't click change the switch.good luck,if you need anymore help let me know.
Mar 13, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Kenmore washing machine: Model 110 20722990. When it gets to the final spin cycle sometimes it works sometimes it doesn't. You can hear it going but the agitator is not moving and it does...
ok first, i need you to do a little test,,,put unit on final spin ,does it spin at this time ,,yes so pick the lid up every so lightly ,,did it stop ...put the unit in final spin again unit does not spin push down on unit lid and it spins..in both cases you have a bad lid switch.,,the part # is 3949238 the picture is how it look,,if you need help installing just repost...good luckonthejob5130_1.png
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
Good evening, My Roper washer RAX4232PQ0 will not spin...it seems to drain OK but won't spin...can you offer any help? Thanks!
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
Jun 09, 2011 | Roper RAX4233PQ Top Load Washer
Have a kenmore elite washing machine which i purchased in 2005. The machine will stop in mid cycle and will start again when the door (top load) is opened and shut again. Could this be a problem with the...
what cycle does it happen in?close the lid and open it a few times,does it make a clicking sound,if it does i would say the switch is good,also you can do this,next time it happens open the lid carefully without banging the machine so you don't disturb anything,get a screw driver and stick it in the hole and see if it runs, if it does i'd say it's the switch,but i've seen this before right before it goes into the spin cycles,the clutch doesn't fall in the tranny. and when the lid is opened and closed the clutch falls.keep an eye on it and see where on the timer this happens,make a mark and see if it does it in the same spot,depending on how hard you close the lid it could be the switch,the timer sticking,i've tapped the timer when something like this happens and it sometimes starts or the clutch in the tranny,when you close the lid did you ever notice if you heard a clunking sound and then it starts to spin..also if you open the top console,unplug the lid switch and stick a jumper wire in the two outside holes of the part you unplug,the lid switch is closest to the right side clip and it's a white connector, you can bypass the switch to check it, all it is is a safety so the machine won't run with the lid open or instead of doing that you can stick a screw driver into the hole and let the machine run like that if you think it's the switch,let me know what you find.
Apr 19, 2011 | Washing Machines
My Kenmore 22712 Top load will agitate, but when it switches to the spin cycle I get nothing. The motor wont run and the tub doesn't spin.
open the lid a lttle and close it down a few times,if you don't hear a clicking sound when it closes you have a bad lid switch,or open the lid and stick a screw driver in the hole where the piece on the lid goes down into when the lid is closed, if it doesn't click and the machine doesn't run then the lid switch is bad.,they don't want the machine to run with the lid open when it goes into the spin cycle,if you send the full model number located beneath the lid when it's open on the back panel under the lid.let me know how you make out
Jan 13, 2011 | Kenmore Washing Machines
My Kenmore 400 washer does the following. If I start a wash cycle it goes through entire wash cycle without draining ever, just washes until it ends. If I lift and close the lid when the timer gets...
lid switch stops machine from spinning when the lid is open, Make sure the lid is fully closed. Loose screws on the lids right side not holding metal arm properly, or the arm is not positioned properly (the end which is pointed down when the lid is open needs to be slightly farther away from you, towards the back of the machine, to actuate the switch fully: or the lid switch itself which is underneath the top,
Jan 03, 2018 | Kenmore Washing Machines
Problem with spin in rinse cycle
Yeah that is a lid switch problem. I have a page I compiled that shows how to fix this easily: HERE
Jan 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate careII spin cycle
sounds as if perhaps a wire is off on the side of the motor assy, l;ook at he wiring harness, sometimes a "chugging " noise occurs form the motor when one of the harnesses is not attached. and yes its normal to wash with the lid open, not to spin however( thats a saftey issue)
Jan 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not drain or spin
The symptoms you are describing are usually caused by a bad lid switch. The washer will fill, agitate, but when it starts to go to the rinse cycle, the washer stops and will not advance any further. The lid switch is located on the right hand side of the wash tub opening on most top loader machines. Check to see if it has come loose. There are two screws holding it in place. Additionally, there should be a small plunger on the lid that pushes down on the switch to activate it when the lid is closed. Make sure this plunger is intact. If your washer does not have a lid switch mounted on the right hand side of the lid, it will be located on the left hand side in the rear under the console. A simple test is to open and close the lid and listen for a "clicking" noise. If you can't hear the contacts closing, your switch is probably bad. In the case of the rear mounted lid switch, there is an arm on the lid that activates the contacts. Sometimes the arm becomes bent and will not close the switch contacts. Generally, the repair is simple and a lid switch usually runs about $35. If you post back with your model number I can get an exact part number for you and give you step-by-step instructions on how to replace it. Let me know. I hope this helps you.
Nov 13, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
13 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
