Question about GE GTS22KBM Top Freezer Refrigerator
Ge refrigertor side by side,the upper part of both side is not cooling well,and the bottom of both side is very cold,what is causing it,how can u help me fix it ?
  • Mark Egan May 11, 2010
    Is the freezer fan running? Cold air falls, warm air rises, so that is somewhat what happens in each compartment of your refrigerator. Check that the light goes off when you closer the doors. Check out my "Tips and Tricks" for checking the door gaskets. And finally, check to see if there is a heavy ice buildup on the freezer coils. If so, and the fan is running, then you could have a defrost problem. Reply back what you find, and I will help you more.
  • 126 Answers
TWO THINGS TO CHECK FOR.1ST. IS THE FAN IN FREEZER WORKING?IF NOT MAKE SURE NO ICE HAS BUILT UP AROUND IT.IF NOT REPLACE FAN MOTOR.2ND DO YOU HAVE FROST BUILDING UP ON REAR WALL OF FREEZER ?IF SO AUTO DEFROST IS NOT WORKING AND YOU WILL NEED A HEATER OR DEFROST TSTAT.YOU CAN DEFROST IT MANUALLY 6-8 HRS WITH DOORS OPEN AND UNIT WILL WORK FOR ABOUT A WEEK TILL ICE BUILDS UP AGAIN
Posted on Dec 12, 2009
Frigadare refrigertor side by side its cooling fine but the freezer wont freeze
Check the heater coil in rear of freezer. Mine was burned out. Letting ice build up on the cooling fins. Replaced with new type double heater coil and fixed proble. You'll have to remove the cover off rear wall of freezer section to access it.
Jul 04, 2014 | GE GSS20IEP Side by Side Refrigerator
Refrigertor is running but the freezer is not that cold, and even the fresh food side the foods are not getting cold on the top 2 shelves what could possibly cause this problem..
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
GE refrigertor profile no cooling
may be the main pc control board . bery comon . or some timer the compressor relay's .. mm
Jul 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side fridge freezer warm on upper levels
the cold coil is in the freezer side at the bottom . the fan moves the air over coil . ck that your fan in freezer is working . mm
Apr 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE GSS22SGMBBSCC side by side refrigerator does not cool the upper freezer portion
Most newer GE fridges have dc fan motors controlled by a computer board. Sometimes the board just fails and sometimes the fan can cause the board to fail.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Only bottom part is cool
The next step is to replace the thermostat timer thats causing the build up on your freezer . hope this helps AJ
May 12, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
GE GTS22KBM Top Freezer Refrigerator Logo
71 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
