Question about Mattel Barbie Girls MP3 Player
What does it mean to store up to 120 files - Mattel Barbie Girls MP3 Player
  • 7,482 Answers
When it says you can store up to 120 files, it means you can put approx. 120 pictures, 120 written files, etc. on the player...it is all according to the size of the files/pictures.
Posted on Dec 12, 2009
SOURCE:
How to permantly delete a Kodak hidden file
Write once means. Data is permanent. Just like you can't modify audio cd's or movie dvd's
Aug 21, 2012 | Kodak DVD-R 4.7GB/120 Minutes 16X...
What does memorex dual layer dvd+r mean? How do you record a movie that is over 130 min. We purchased 240 min just for this reason and we can not get it to record over 120. How do you finish recording the...
Well all DVD+R mean that when you finish copying files to the disk, the disk will lock itself and not allow any more files to be burned onto that DVD. The reason why you can'f fit your movie onto the disk is because the movie file may be bigger than the amount the DVD disk can hold. Just because the time of the movie is less than what the DVD can hold, doesn't mean its going to fit. Take for example a Blue ray movie, it may only be 120 minutes long but the file of the movie can be over 2 GB of space.
May 12, 2011 | Memorex Products - Memorex - Dual-Layer...
Need cable from outlet to printer
If "outlet" means 120 Volt AC Power Outlet, then you need a standard 3 wire PC power cable.
If "outlet" means the UBS port on your computer, then you need a USB A to B cable.
If "outlet" means the parallel port on your computer, then you need a computer parallel port printer cable
All of the above are available at computers stores, Stapes, Office Max etc.
Regards,
Yavacotech
Mar 11, 2011 | Office Equipment & Supplies
When attempting to update my bdp-120 blu-ray player, I continue to get an error message saying I have more than one sofware file on the USB memory device. The only file on the device is the update. How can...
You need to format your usb memory device which will mean that everything will be erased from it so move anything you want to save first. Before you attempt to place the file on the usb device again make sure it has been unzipped first.
Feb 05, 2011 | Pioneer BDP-120 Blu-Ray Player
My Toshiba external hard disk does not accepting backup from mac G5
my external HDD is not letting me drag and drop files from my mac. Is this my mac being secure? If so how can i remove it so i can store audio files on this device. thanks
Jan 23, 2011 | Toshiba 120GB USB 2.0 Portable External...
Unable to open the folder in pendrive
The "Personal Data" folder stores all necessary data for StoreJet elite software use (including elite backup files storage). If you would like to backup files into personal data folder, please refer to the manual to use data-backup function.
(http://www.transcend.com.tw/Support/DLCenter/Manual/StoreJet_elite_EN.pdf).
Please do not manually store other data inside this folder. It might cause the software/system to function abnormally. We suggest user to store data at other different folder/path, and avoid occupying "Personal Data" folder. blackbar_left.jpg Print blackbar_right.jpg
Oct 28, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I want a 100 watt electric stove with oven to put in my bunkhouse so I don't have to add 220. I don't even know if there is such a thing.
I believe what you mean to say is: you want an electric stove that works with 115-120 volt and not 220-230 volt. Yes there are stoves available that work from 115-120 volt but they are vbery limited in availability. also, do you mean a true oven or just a stove top burner ? stove top burners are fairly easy to find in the regular 115v plug-in style at hardware stores or through catalog order (usually not at appliance stores). If you are looking for an oven with 115v plug-in ability, it will be a bit herder to find.
Aug 10, 2010 | Kitchen Ranges
The light in the pendrive is off when the drive is inserted into the pc The drive becomes hot when inserted into the computer
Hello. The ON light off (meaning data transfering) and the drive becoming hot means that a chip - probably the one inside the case is bad (that's why the high temperature) so what you need to do is replace the case. Remove the hard drive from its case (probable a few screws) and verify if it is EIDE or SATA interface (I'm 90% sure it's SATA) then go to any computer store an buy another 2.5" case ($25 or so) for your hard drive and connect it to the computer. Hopefuly nothing happened to the drive itself so you can do a backup of the files you had in there. I hope this helps. Please do not forget to rate and provide positive feedback for our support today. Thank you :D
May 10, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Western Digital WD 1200VE; 120 GB external hard drive unable to boot
good eve prapad dont worry for your data ,first if you have a boot cd ,owerrite the OS ,then select repair option,it is occures due to 90% OS currupt ,
regards prasanna
Mar 05, 2008 | Computers & Internet
Mattel Barbie Girls MP3 Player Logo
53 people viewed this question
Top Mattel Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Mattel Audio Player and Recorder Expert? Answer questions, earn points and help others
