Question about Maytag Neptune Washer
Maytag Front load washerMAH8700AWW.
Maytag MAH8700AWW. error code E3
    President:
  • 1,891 Answers
I have a maytag mah7800 also / great machine . never had a problem yet . if you remove the screws in the back holding the top you can lift it off . inside you wil find the tec sheet . on the side in a plastic sleeve . in it is the code . it will also tell you what to do ,. mm hope this helped . let us know mm
Posted on Dec 12, 2009
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Neptune mah8700aww has a e3 code
The Neptune can sometimes be reset. God knows the repairman for Maytag really needs to get back to work, yet to reset the cpu on your washer/dryer just unplug the unit for 60 seconds. I hope this helps you out.
Oct 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
I have a Maytag Neptune MAH8700AWW that give an E3 error code. Is there anything I can trouble shoot thru the Service Mode?
Hello. This link will take you to a web page with a discussion concearning your problem. It's 2 pages long and gets a little technical but does come to a conclusion.
http://applianceguru.com/forum2/6484.html
builderdale
Jan 19, 2010 | Maytag Neptune Washer
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load whasher MAH8700AWW Error/Information code OE is showing and does not show up in owners manual. What does this mean
my maytag mag8700 (4 yrs old) has begun to shake so bad itt walks 4" to the wall. it did not do this before. i regularly get SUDS code. i did run afresh through 3x's. 2 weeks later i have SUDS code again HEPL!
Mar 23, 2008 | Washing Machines
Washing Machines Logo
619 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
