Question about Saeco INCANTO DELUXE Espresso Machine
My incato deluxe exprsso machine steam knob came off is this easy to get back on, if so how??
  • dearnemorphe Dec 12, 2009
    Thanks for the fast response the knob has a plastic bit attatched to it, it has 3 prong bits and a rubber o ring is this how do i aline it?
  • 1,089 Answers
Hi It just snaps back in, but you have to align the tabs before pushing back on.
Posted on Dec 12, 2009
1. Where is the lever located in the Saeco Incanto De Luxe located? 2. How do you decalcify the same same product? Thank you for your help
Hello Dolls36,
I understand you have two questions the lever question I assume you are taking about the steam lever. The second question is how do you descale the unit.
Lets answer the first question first. The steam lever is not a lever but a knob. The knob is located on the right side of the unit.
1. Put container under steam tube turn knob downward to open until you get steam
2. Once you get steam turn knob upward to close
3. Put item you want to steam under steam tube and open valve back up to steam
Now to answer the question about how to descale the Incanto De Leluxe. When you are ready to descale the machine follow these steps.
1. Hold down the "x" button for 5 seconds, the machine will tell you it is ready to descale
2. Remove the filter
3. Fill the water tank with your descaling solution
4. Insert a container under the steam tube and open the steam valve
5. The machine will display descaling and finished
6. Then it will prompt you to fill tank with clean water for rinsing.
7. Press the "x" button once tank is full
8. Place container under steam tub and turn knob to open steam tube
9. When finished press "x" button one more time to confirm done
10. Replace water filter and fill tank
I hope that I have answer you question as for question 1 I assumed that is what you were asking about. However, if that was not the right question please post back to this tread and I will be more than happy to answer the question that you specify.
Thank you for choosing FixYa.com
Justin
Mar 11, 2011 | Saeco INCANTO DELUXE Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Hi my saeco incato deluxe coffee machines steam knob fell off please help
Hi
Removed the top cover and locate the tap body. Line up the steam rod, press the lobe on the rod and push in to the hole . The lobe slide in the groove of the body when you turn the knob.
Dec 12, 2009 | Saeco INCANTO DELUXE Espresso Machine
My Saeco Incanto deluxe started dripping hot water from the steam spout outlet when coffee is brewing. It produces steam and hot water without any problems. It doesn't leak when it's in a normal state...
Either the grind is too fine and there is so much pressure that the pins in the steam valve are not working properly. First try to adjust grind a little coarser, it that does not work, then the pins in the steam valve need to be replaced.
Nov 20, 2009 | Saeco INCANTO DELUXE Espresso Machine
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeko incanto delux
It was an easy solution in the end. Just opened the steam knob vent for the steam to escape and vioala a great coffee was on its way......................
Apr 13, 2009 | Saeco Magic De Luxe Espresso Machine
Water pump does not work
Try to open the steam knob and turn on the button to make coffee, when the water flow out off the steam pipe, close the knob and the button.
Jun 06, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Saeco easy exprsso
If you take off the bean hopper then you can see the grinder. You can turn the ring anti clockwise to get the knife out.
When you put it in again you have to turn the ring clockwise to the end then you take it back 14 step and then the grinder is in middle position. Hope this will help you
Dec 21, 2007 | Saeco Easy Espresso Machine
Saeco INCANTO DELUXE Espresso Machine Logo
44 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
