Question about Kitchen Ranges
2006 colorado abs fault light came on now and then changed abs sensor now light stays on all the time
  • llkaz Dec 12, 2009
    Hi I had the brakes redone pads@rotors drove the truck approx 1 month then abs fault light started to come on intermittedly, put scanner on and replaced left front ABS sensor now ABS fault stays on all the time.
  • Mark Egan May 11, 2010
    GM ABS modules are known to be problematic.There is a company on the internet that rebuilds them for $150.00 or so, and warrants for 5 years. I had mine done about 1-1/2 years ago. Company was in Russia, IA I think. I found them on Ebay by typing in GM ABS repair. Let me know what you found.
    President:
  • 1,214 Answers
Am betting you have the ABS problem I mentioned. I went through exactly the same headaches before shipping mine off.
If you go to their website, they give instructions as to how to tell if your module is bad, if they can repair it, and how to remove it without rendering the vehicle immobile. They are quick with the repair and turnaround (mine was a total door to door of 5 days.).
Posted on Dec 12, 2009
2006 chevy colorado abs light on changed left speed censor
if you broke sensor wire at the electrical connector.the dealership more likely can get you another sensor connector with new wires splice in new wires and connector.
Nov 12, 2011 | 2006 Chevrolet Colorado
Why does my ABS light stay on after I start my 2006 Torrent
If the ABS light is on it means there is a fault in the ABS system. You will have to take it in to a mechanic and get the computer scanned to find out what part of the ABS system has faulted. Most of the time its a wheel speed sensor. Until the faulty part is replaced the ABS light will be on & your ABS will not work.
Feb 27, 2011 | Scosche Industries Scosche Dcgm16...
Changed my front brakes and rotors..ABS light came
did you knock off a wire on the sensor ,or even break the sensor unit when you changed the rotors..
Jul 11, 2010 | 2006 Chevrolet Colorado
Abs light is on
try removing the pos. battery cable for 10 seconds then replace it, if you lost fluid fill it up to full line ,or to top, hope to help you, robert b.
Jul 11, 2009 | 2004 Chevrolet Colorado
2005 chevy colorado abs fault
Sounds like water getting in one of the connectors. You will need to see what fault code is in there when the light comes on, then look at that sensor.
Jun 05, 2009 | 2005 Chevrolet Colorado
Abs fault light on and noise from abs
one of your abs sensors is faulty also check that there is no rust on the tabs that the sensor reads from.
Jun 04, 2009 | 2004 Chevrolet Colorado
ABS light stays on
have you had abs system checked with a scan tool?if you cannot communicate with abs module with a scanner,there is main power feed circuit that corrodes under fuse block underhood..also have seen corroded wires near abs module over top of transmission..if you have communication..you may have a speed sensor fault..if a front sensor,check wiring behind splash shields in fenderwells,if rear sensor fault,most likely sensor is defective..also check for water intrusion into rear wheel bearings by removing sensor from hub unit
Apr 16, 2009 | 2006 Dodge Caravan
Abs fault
check and make sure u did not damage or disconnect the wheel sensor(s), that would be just about the only thing u could have done to cause this issue, u might want to have the system tested for trouble codes to confirm this wheel sensor possiable fault.
Mar 10, 2009 | 2004 Chevrolet Colorado
Shows ABS fault on dash and ABS light stays on
Check your abs connectors they might have pulled a wire loose
Nov 11, 2008 | 2004 Chevrolet Colorado
Kitchen Ranges Logo
239 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
