Question about Maytag Neptune MAH5500B Front Load Washer
I need to replace the boot on my washer. Any ideas?
    President:
  • 1,891 Answers
Open door and remove the 4 screws 2 in hinges and 2 on other side . then grasp the two side corners and give it a tug /front sholud come of . tilt out and remove. remove the two l brackets top corners 5/16 screws . this will release top /be sure to remove the dist cover 4 screws on top. lift top . you will fint a spring and wire running around boot . pull togther to relace . remove boot . reverse to install boot mm
Posted on Dec 12, 2009
My Frigidaire stackable washer is leaking from the bottom
that depends on who is fixing it, if you are doing the repairs it most likely the boot seal, other wise you have to call sears.
Washer Door Boot Seal Replacement Frigidaire Washing Machine Repair Part...
Apr 28, 2015 | Cars & Trucks
Kenmore HE2T Front Loading Washer Leaks From Door
there is a dispenser hose that goes in the tub.alot of times a sock or something gets inside that hose.that would cause your trouble.take the boot off the front and look up and left to see that hose.it comes out of the tub pretty easy.
Feb 03, 2010 | Washing Machines
Need access kenmore elite washer door latch wiring any ideas
remove the front retainer to boot and pull back on sw side / do not remove complety and you should be able to remove sw and get to wires . not a tuff job . mm
Dec 06, 2009 | Kenmore Elite 45986 Front Load Washer
My whirlpool front loader washer leaks water in front of the washer from the bottom of the machine. It does not happen with every load. Any idea on the problem?
Check the rubber boot just inside the door. You have to push the drum back slightly and rub your fingers around the entire boot. I had a similar problem and a key had fallen out of a pocket and cut into that boot. The leak would run out of the damaged boot then come out the bottom onto the floor. I purchased a new boot and it took me about 30 min to install it. The problem was solved. If the rubber boot is fine then the over soap thing is probably your problem.
Oct 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Nepture washer Model MAH 5500 boot mildew
The new boot replacements are anti-microbial have a smoother surface and are designed to be more resistant to mold issues with proper care. Unfortunately, there are still a lot of the old boot replacements out there. The part number for the upgraded boot is 12002533..., This part number supercedes all prior part numbers for the Neptune boot assy...Hope this helps
Jul 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
Leaking water on the floor - Replacing Rubber boot
Type in your make and model and repair manual into the top right hand address bar of your pc. Scroll down the list and you will find the repair manual for your machine. I got full instructions to remove and replace the bearings on my hotpoint this way..
Best of luck
sue
Jun 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Leaking from the front of washer and moldy odor.
you need to replace the front boot what a pain you may need a tech to do this also you need to keep door open and wipe the boot with a towel after each use this is a common problem with front loaders.I do warranty work and run across this problem alot
before you replace boot turn on washer with nothing in it and let it cycle if you see suds in water you are using to much soap and this will cause the machine to over fill check this first
Dec 02, 2007 | LG WM-2277HW Front Load Washer
Sears name:model 417.44102300
its glued on take a razor blade and carfully cut the glue between the front panel and the boot
Sep 10, 2007 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
141 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
