Question about Panasonic Televison & Video
Tv just turned off and when i unpug it and plug it back in it truns on for 30 secs and turns back off
  • Panasonic Master
  • 1,229 Answers
You have a bad solder ground or even a bad capacitor. Check for rings around the pins if ICs and transistors that are mounted on a heat sink. And use a cap checker to find the bad cap...there should be one or two to replace, but you will search and find!
Posted on Dec 12, 2009
My soniq tv is stuck on audio how can I turn tv back on ?
Try unplug the set from the wall. wait 30 secs and plug back in and turn on tv. Need model number
Oct 22, 2013 | Televison & Video
Only turns on when plugged into computer. power button will not turn mp3 on or off
Hi! unplugged ur MP3 to ur Computer, try to refresh ur MP3 player by pressing the power button in 5 to 30 secs... then trun it on Best Of Luck!
May 29, 2011 | SanDisk Sansa Clip MP3 Player
Error 105 (net::ERR_NAME_NOT_RESOLVED): The server could not be found.
Try a router/modem reboot.
1 turn off pc/and power off router
2 unpug all cables on router
3 leave off for a min 60 sec
4 plug all cables back into router and turn on
5 restart pc
May 29, 2010 | Microsoft Windows XP Media Center Edition...
Error105 (net:ERR_NAME_NOT_RESOLVED)The server could not be foun
Hello
5 restart pc
Apr 23, 2010 | Microsoft Windows XP Media Center Edition...
Just bought this used Mitsubishi WS-55809 and when I turn it on the pic. is all messed up. The write is deformed looking and all the words are repeated 3 times. I hit the back of the TV and the pic. and...
Sounds like you have some solder problems on your deflection board. If you're up for it, you could fix that yourself with some solder and a soldering iron. Just take the back off, and look for the board with 2 of these on it (numbers may be different).
Remove the board carefully noting where you unpug things (take photos if needed). Then reflow the solder joints on these parts. I hope this was of assistance, best wishes.
Mar 29, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Turn power on, approx. 30 sec later it the power
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
Nov 11, 2009 | Zenith Z19A11S TV
Dont have securtiy code to unlock tv
  1. Press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in.
  2.  Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
  3. Volume down on the unit and RH-Split on the remote-- same process
Try these one at a time until you find the right one.
Let me know if this helps and please rate this solution. Lone99star
Jan 18, 2009 | Panasonic TC-32LE60 32 in. LCD Television
POPPING NOISE FROM SONY TRINITRON KV-30HS420
dont use high volt arcing can do lots of damage. unless you can be sure comtng from speaker.
Nov 20, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
My tv will not turn on
Open the back cover and check the Power Supply board. If you find some puffed capacitors, just replace them.
Apr 19, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
