Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
I plugged in a Bose Sound System, but for some reason, it doesn't make sounds. I did everything the instructions told me and I even tried it on a different TV and it worked. How do I fix this problem?
  • Sony Master
  • 8,457 Answers
Check all the menu setting,Make sure all the audio setting is Varible out not fix audio setting.
Posted on Dec 12, 2009
SOURCE:
Bose Life style 535
I had same problem once,i bought a new HDMI CABLE the salesman told me that my HDMI cable has loose grounding.
Feb 04, 2014 | Bose Lifestyle 38 System
The remote will not turn on the Bose System intermitently.Need to turn the power off for TV & Bose unit & then back on for it to work.
If your system is plugged into a surge protecter, the Bose service guy told me that sometimes the Bose system detects a surge and automatically shuts down. Unplug the system for 5 minutes and then plug back in. This works because it happened to my system. I called Bose and this is what I was told. It worked!
Dec 27, 2012 | Bose Solo TV sound system - Black
My Ipod Touch doesn't fit in the Bose Sound Dock
The most cost effective bet is to fit a charge upgrade or a Bluetooth and charge upgrade yourself. It takes about five minutes. The complete kit is available form invebo.com and you don't need any special skills. click here to see the instruction video
Jan 01, 2012 | Bose SoundDock digital music system...
I am trying to connect my bose cinemate speaker system to my new sharp Aquos Quattron tv but I am not having success. I called Sharp and she told me to put the TV on the variable select mode but this is...
I assume you have everything hooked up? You should have the Audio Out from your interface module connected to the Audio IN of the TV. The sound should be set to fixed, not variable. Variable means you control the sound output from the TV which controls the sound from the Bose. Not Good. Sound quality is not as good and confusing to customers. Make sure your selecting the right tv input on the Bose system. You should be good to go.
Dec 27, 2010 | Sharp Televison & Video
Bose Lifestyle 28 Sound Problem
I also get this problem sometimes with mine. Usually when you call Bose they suggest that you do a "hard" reset meaning you unplug the power cord from the wall and wait about one min. Then plug the unit back in and it should work.
The other thing that you can try if the system still isn't working is to check that all the wires running into and out of the sub-woofer are all plugged in and aren't loose.
If either of these two solutions don't work you can alway call Bose tech support @ 1-877-210-3782 (they are open Monday Friday: 8:30 AM 8:00 PM ET)
Mar 31, 2010 | Bose Lifestyle 28 System
My bose dock has power but no sound the remote dont work but it charges the ipod wot can be wrong
i spoke with bose tech support today because my docking system had no sound...everything else was fine, but no sound. they told me to take the battery pack off of the back, then reset my ipod by holding down the center button at the same time as the menu button for about 5 seconds (the apple icon will display), then reconnect the battery pack to the back of the dock and retry. it worked! good luck.
Jul 07, 2009 | Bose SoundDock® (Black) Docking Station...
Bose Companion 3 series II speakers aren't producing sound (imac)
from what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
Dec 26, 2008 | Bose Companion III Computer Speakers
Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Sep 01, 2008 | Bose Lifestyle 28 System
Bose companion speakers
hmmm.. well if you system is like mine it has multiple ports for sound. Try the speaker plug in the front of the machine.. better yet .. to ascertain whether or not it is your speakers or sound card issue then plug some headphones in to the port and see if you have sound. Never forget the basics ...is the sound muted? Open your sound eq application and see if the wave output is turned down.
Keep me posted!!! and Good luck!
May 30, 2008 | Bose Companion 3 Computer Speakers
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
