Question about Sanyo 42 in. LCD TV
White color is exposing up above all the other colors
White color is exposing up above all other colors.Means is brighter than the other colors,and it gets worse every day.
  • Sanyo Master
  • 8,457 Answers
Ur backlight video board is dying,must replaced to solved this prob.
Posted on Dec 12, 2009
I am trying to install a ceiling fan and from the ceiling I have a copper white and black wire. Now from the fan itself there is a black blue and white wire. Not sure where to connect the copper wire.
Good question, proper wiring is a crucial virtue that needs to be one hundred percent accurate.
Three wires showing from the ceiling lamp fixture harness, positive, negative, and ground.
The negative wire is the white wire,
The Hot wire (positive) is the wire of brighter color than known negative,
220V AC (alternating current) home wiring to(" duplex outlet switch, GFI switch, single/dual pole light switch, lamp fixtures,") the Hot wire or lead, is normally Black, the lighter color, or White is neutral or neggative,
Neutral wire (completes circuit) allows current flow to continue through to other parts of house, Alternating current.
The Ground wire is usually wrapped in green color, or unmarked copper.
The copper wire from the ceiling will need to be grounded to the metal bracket on the new light fixture, a gold or silver screw, sometimes tagged with green, is the proper grounding location, Any place on Metal not attached to ceiling bracket, Ground should be attached to metal on fan,
White wire from Fan is neutral, Negative.
Black wire from Fan is Hot Wire, Positive,
If Blue wire from Fan is Not Manufacture spliced, Meaning no Copper is exposed, Wire is not used, Blue wire is NOT ground,
If Fan has a light, Voltage from Hot Black wire will supply both light and fan functions,
Safety First.
flip off breaker switch to the room fan is being installed.
Doubble Check
Black^Black wire connection is secure.
White^White neutral wire connection is secure.
Ground is fastened securely to metal or wrapped under a screw.
Using splice caps is recomended, The plastic shell encloses the wire connection ensuring No stray copper is exposed, limits possibility of cross wiring.
Google the brand of fan being installed, and Check wire color code, and wiring diagram, Info good to have, and checking twice will only guarantee Lamp Fixture Install Well Done.
(Blue wire may be there for installing multiple ceiling fixtures in a loop circuit, so all controlled by same light switch.)
Enjoy Your New Fan,
Jos
Thoughts&Comments, encouraged jtobias1020@gmail.com
Mar 26, 2017 | Dryers
Konica Minolta c451 is showing white linen the printed work
for black and white??? or a color????? Means you might have something blocking the LASER for that color. print out a test chart for each color which one has the white line?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 22, 2016 | Konica Minolta Office Equipment & Supplies
Hi! I am experiencing difficulty with the brightness on the screen of my GameBoy Color. Is there a way to adjust the screen brightness, so that it would be brighter? -Stine
Unfortunately, the Game Boy color has no backlight, so there's no way to make the screen any brighter. You can change the contrast, but that will only affect how dark things appear on the screen. Sorry.
Mar 16, 2011 | Nintendo Game Boy Color Console
I need to know how to wire up my signal lights for my 1984 honda shadow vt700c motorcycle
All Honda turn signals wire the same. The wires are color coordinated and the same on all models. Sky blue wires are for the right side and orange wires are for the left side. The running lights the same colors (blue on right and orange on left) they just have a white stripe or a white band on the blue or orange wire. The most important thing to remember is the turn signals have to ground to the green wires in the harness not to the frame. If you do not ground the signals through the wiring harness you may have issues down the road. Every motorcycle I have purchased that had a windjammer fairing on it, had to be rewired. The turn signals had not been wired using the green ground wires and they did not work correctly. The turn signal should be flash brighter than the running light. If the running light is brighter than the turn signal the offending front signal is wired backwards.
Mar 03, 2011 | 1984 Honda VF 1100 C
I have windows 7 and do not care for the way it looks. \r\nMy old xp would let me change all the white to a custom color. W7 will not let everything change. I am visually in paired and see things brighter...
Ok - this can be done - step by step...
1. Control Panel\All Control Panel Items\Personalization\Window Color and Appearance
2. At bottom of that screen: Advanced Appearance Settings.
3. Top selection drop down - find Application Background.
4. Change that to a more agreeable color.
5. Save changes.
6. Enjoy a PC that you can look out without being blinded by the bright whites.
Cheers.
PS - Tested on my Windows 7 Home Premium.
Nov 27, 2010 | Dell Inspiron 560S Desktop Computer (Intel...
What is a good Microwave Leak detector - make  absolute measurements? Can a cell phone be used to detects leaks from Microwave ovens.?
I replaced two convergence chips the resistors were all fine. This took care of the 3D look. I also replaced the coolant in the blue and green although it was the blue which was badly contaminated. The picture is now clearer than before but I am unable to get color. I can see vibrant colors when I pull up the TV's menu. I can see the colors in the convergence menu as well but no color in the picture. The color controls only make the picture brighter or darker. It is sepia in color not black and white. What could this be?
Feb 22, 2010 | Philips 51PW9303 51" Rear Projection...
Some of my pics come out every white how do i fix that .when i take pics they come out very white but all of them do that.
If they are white that means they are getting over exposed. You may have your camera in a manual mode that is set to overexpose the pictures. You can set it in an automatic mode to take care of this. The other possibility is that you have a exposure adustment that can be set at either + for brighter or - for darker. It should be set at 0. Sometimes this is a EF option on the camera. Hopefully this helps.
Jul 16, 2009 | Sakar 90379 Digital Camera
Gps color not bright
I contacted lowrance tech and we came up with the software has a no 1.1.0 the new one has 1.2.0 . We are not sure is changing this will make it brighter,they are going to send me some thing to try.
Thank you for your response
Seayagrandpa@bellsouth.net
Apr 02, 2008 | Lowrance GPS
Monitor gets brighter
Well... it's time for a replacement. It's seems your AD Board begin slowly to dies out... Eventually will turn to white screen.
You'll need a new AD Board.
Mar 10, 2008 | Fuji FP-768 17" Flat Panel LCD Monitor
Color on the T.V. i think is gone
Ok what we need to do here is determine if the picture tube is still good or not??.. If you turn the tv to a station thats has a brighter scene and turn off the color what does the pic look like ??is it Black and white or a certain color overall on the screen??
Apr 02, 2006 | Hitachi 36FX48B 36" TV
Sanyo  42 in. LCD TV Logo
292 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
