Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Water drips at dispenser - GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
    President:
  • 1,891 Answers
If it drips all the time / raplace valve. as it's not shutting off . the valve is in back where the water line hooks up . change one wire at a time / don't mix them up .. mm
Posted on Dec 12, 2009
Water dispenser drips after use but doesn't shut off completely and drips constantly.
Most likely the water inlet regulator (water valve) is faulty (like a leaky faucet) need to replace the water valve.
Jan 30, 2014 | Samsung RF26XAERS
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | Kenmore Refrigerators
Our Kenmore side by side model number 10653382300 is having a problem with the water/ice dispenser. The water dispenser continues to drip and I can not get it to stop. How can I fix this problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jan 08, 2010 | Refrigerators
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water dripps
I realize this is an old answer, but I'm experiencing the same problem and found what I hope is a much simpler fix:
https://youtu.be/hAEdjhaZoaQ
This is a Youtube video which explains how air trapped in the water line can cause a drip from the dispenser. Apparently, allowing a gallon of water to flow continuously through the dispenser should...uh...dispense with the problem!
Hope this helps you, and me!
Sep 21, 2008 | Samsung RS2534 Side by Side Refrigerator
Water Dispenser Drips
Had the same problem after replacing over seven water valves and installing a water regulator in the water line to the refrigerator with no help. Had to reduce the water pressure to about 27 pounds the reduce most of the drips. It drips an amount about the size of a quarter and when the water gets the coldest it stops the drip, but there is always a droplet at the end of the water disperser tube.
The problem is with water stored in the refrigerator side of the box. Water come in and does not leak. After the water gets colder it expands and oozes drips from the water dispenser. It is worse with the roll of tubing behind the crisper drawer on the bottom, because there is no room for expansion in the tubing. We replaced the tubing with and older style tank and it helped some, but not completely. The solution is 1. Try to buy a refrigerator with a tank instead of the roll of tubing in the bottom of the refrigerator side. 2. Don't use the water dispenser. 3. Reroute the tubing directly to the water dispenser and bypass going into the refrigerator, the water will not be as cold. 4. Avoid those built by Whirlpool.
Oct 04, 2007 | Hotpoint HSS25GFP Side by Side...
Water dripping from the water dispenser on freezer
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
Sep 30, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser dripping
Your house valve may not be totally closed (bad seal or something) letting a small bit of water through. Disconnect the line to the fridge completely (in the back) to be sure. That way even if the fridge solenoid valve is bad AND the house valve is bad you won't get dripping. If you know the valve is good, there are times when the water filter will have air trapped in it letting the water in the line drip out slowly until it's finally empty. Pull any filters you have also.
Feb 16, 2007 | Kenmore 53582 / 53584 Side by Side...
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
64 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
