Question about GE Refrigerators
Ge fridge getting warm
When it gets warm everything shuts off like its going through defrost but last along time temp in frezzer gets up 45-50 deg it does not have a defrost timer it has a control board
  • 126 Answers
DEFROST CYCLE LASTS FOR 20--30 MINS.AND TEMPS WILL REACH WHAT YOUR READING FOR A SHORT PERIOD OF TIME BUT NOT LONG ENOUGH FOR FOOD TO START TO DEFROST .HOPE THIS HELPS.PLEASE RATE MY RESPONSE :)
Posted on Dec 12, 2009
GE Model GSS25JFMWW, started with the ice maker not working, then the water doesn't work half the time. Now the freezer and Fridge both stop working, and out of nowhere the will start again after a couple...
Hi and welcome to FixYa, I am Kelly
The ice-maker not working was a sign that the freezer temps were rising above 14 - 16 deg F. There ice-maker has an internal thermostat that activates the harvest cycle when the temps reach around 15 deg F. If the freezer is warming up it will never make ice.
What is most likely causing the recent symptoms of the unit shutting of and not stating for a long period is either an intermittent defrost thermostat (
The unit has a timed defrost cycle to START the cycle but there is a 60 deg F thermostat that opens to terminate the defrost cycle. If the defrost heater does not work the unit has to slowly warm up toward room temp without heat to reach 60 deg F for the defrost cycle to terminate. This can take a very long time if the freezer is more than 50% full as the contents will keep the temp below 60 deg F for an extended period.
I suspect you have a defrost element failure. Item 230 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210406&diagram_id=22357329#d22357329
You should read resistance across the defrost heating element. No resistance = open element.
There is the very very remote possibility that there is a problem with the main board. Item 801 this link:
Since the unit works once defrosted I doubt the main board has failed.
There is a thermistor that is item 241 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210406&diagram_id=22357332#d22357332 that can possibly cause the problem.
Thermistor Image:
http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfbXNfNTIwMDFYNTVSVy9IRUcvc290b2hwdHJhcC8%3d
If the defrost heating element is good then this would be suspect #2.
I hate to use someone elses material in a response but this one is so good that it is a must read:
http://www.appliance-repair-it.com/refrigerator-thermistor.html
Bottom line... I still think you have a defrost heating element problem at this time.
Thanks for choosing FixYa,
Kelly
Jan 27, 2011 | GE GSS25JF Side by Side Refrigerator
Entire cooling shut down - restarted 10 hours later, shut down again 12 hours after restarting.
Hi and welcome to FixYa, I am Kelly.
The defrost cycle is usually terminated by a 60 Deg bi-metal thermostat. If the defrost heating element is not heating up the unit will shut off until the internal temp reached 60 Deg F and then restart.
Defrost cycles are 10 - 12 hours apart depending on the defrost control installed so that explains the 12 hr repeat. I really think you have a bad defrost heating element. Here is why I say that...
1. The Defrost cycle is 12 hours after last defrost. (Means the defrost control /board is working)
2. The defrost cycle terminates at 60 Deg F
3. No working defrost element will cause very very long defrost cycles due to the time it takes for the compartment to warm up to 60 deg F and terminate the defrost cycle.
The element is item 33 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164987&diagram_id=28252332#d28252332
Just looking at the drawing it appears that the Defrost heater and defrost thermostat are an assembly.
You should be able to read resistance end to end on the heater assembly. If you have no resistance it is most likely open / has failed.
The defrost thermostat will read resistance anytime compartment temp is BELOW 60 deg F.
Thanks for choosing FixYa.
Kelly
Jan 19, 2011 | KitchenAid Superba Architect KSCS25INSS...
Hi i have a ge profile side by side. the digital temp inside the refrigerator side is reading frezzer 23 refrigerator 47. The frezzer wall is iced up. when i press against the frezzer wall the coil feels...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Sep 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Feb 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a 4-yr old Electrolux 22.6 counter-depth fridge. It has worked fine until now. Now, the freezer will only cool down to 35 deg F and the refrigerator is only 52 deg F with the freezer setpoint at 0...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Jan 07, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
FRIDGE STAYING AROUND 25 DEGREES
you have a gas leak , a refrigeration mechanic is required.
May 10, 2009 | Admiral 26 cu. ft. Side-By-Side...
Warm temp
u have a defrost problem if u shut it down 4 or 5 hrs with doors open then turn back on itll work tii u have it fixed
Mar 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
