Question about Powermatic 1660804K 66 10" 5 HP 3 Phase 208/230V Table Saw w/ 50" Accu-Fence & Rout-R-Lift
The crank to raise and lower the blade on my powermatic 66 is really hard to turn, any suggestions?
    President:
  • 1,214 Answers
The square tooth screw and nut tend to fill with sawdust, which saturates with oil to cause the threads to bind (like a dirty nut and bolt.).
Clean the bolt with a cleaner, then apply a little wax to the threads (crayon or bees wax). Be sure to run the assembly up and down to cover the whole "bolt" and make sure to apply to the point of the screw that assures some of the wax works into the nut.
Wax is less likely to cause wood dust "mud" that WD-40 or other lubricants would cause.
Check the slides or guides that guide the assembly as well. CLean and lubricate with wax as needed.
Let me know what you find out.
Posted on Dec 12, 2009
Difficulty raising and lowering the blade on Delta rockwell10" unisaw 34-450
Ok, basic question...is the lock engaged? It is the small knob at the center of the adjustment wheel. Is it possible the screw has been galled?
Here is the manual- http://content.powermatic.com/manuals/1791227K_man.pdf
May 27, 2014 | Powermatic 1791227K Model 64 10" Artisan...
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have a powermatic 66 table saw. I removed the motor, to move the saw. when i reinstalled the motor, the blade has moved 5/16'' towards the fence.
Check to make sure the arbor set screw is not loose. The bearings may have shifted when you moved it. I recently rebuilt an old 66. Repositioning the bearings and tightening the set screw could be all it needs.
Sep 27, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have cleaned the worm and Gear segment for blade raising mechanism on my 66 and it still binds and is stiff. What do I do next?
Try lubricating with silicone spray. I use it for just such things, and I'm happy with how it works. Also, clean and lubricate the lock on the elevation control.
--W/D--
Jan 29, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
My Powermatic 66 tablesaw has a 3 phase 230 Vac motor on it but I cannot tell if it is a 3 hp or 5 hp. All the tags are gone from the motor. Is there any way to tell from the serial number? 8666-1008.
There will be a tag on the motor that will give the specs. Sometimes they are hard to see from the underside and its not easy to remove the top see them. Try lowering the motor (with blade removed) all the way and use a digital camera to reach up into the cabinet and photoqraph the top of the motor. I had to take several since your shooting blind to get a picture of mine.
Nov 09, 2010 | Powermatic 1660802K Model 66 Special...
How to adjust my til tof my 10
When you are facing the saw as if you would be operating, there are two adjustment wheel on the front and right hand sides of the saw cabinet. The front wheel adjusts the blade height, the wheel on the right side of the cabinet adjusts tilt. Each of these wheels are equipped with a locking nut, a smaller wheel in the center. this must be loosened before any adjustments can be made and should be tightened before operation. If there is significant resistance while trying to adjust either of these it may be a result of misaligned gear or excessive buildup of dust and shavings on the gearing.
Feb 14, 2010 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have a Powermatic 66 that trips breaker
Either it has a problem with a blade brake or the motor is siezing. Or the is a wiring problem. With the unit unplugged check and see if you can turn the blade by hand, if not the motor is the problem. If it does you could still have a motor problem by it drawing to much amperage or the is a wiring problem.
Aug 31, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
Powermatic 1660804K 66 10" 5 HP 3 Phase 208/230V Table Saw w/ 50" Accu-Fence & Rout-R-Lift Logo
197 people viewed this question
Top Powermatic Saws Experts
80stech
Pieter Vleeshouwers
Pieter Vleeshouwers
Raymond Richards
Raymond Richards
Are you a Powermatic Saw Expert? Answer questions, earn points and help others
