1996 aurora heater core
I need the instruction to replace a heater core. And were it is. In the engine or under the dash? thanks
  • 2,039 Answers
The heater core is under the dash and it a big job better get use to work hard thanks for using fixya pierre
Posted on Feb 05, 2008
How do I change my heater core in my 1996 ford ranger
The heater core is located in the heater box, under the passenger side of the dash. Most FORD heater boxes are snap-clipped together, and if you remove the rear panel from the heater box, you will see the heater core...it looks like a smaller radiator...twist the heater hose off of the heater core (x2) from the engine side and gently remove the heater core from under the dash. When replacing the new heater core, be very careful re-installing new hoses to the core...it is a fragile thin metal that can leak almost instantly if tweaked too roughly...replace all parts in reverse order of removal.
Feb 01, 2015 | Ford Ranger Cars & Trucks
Coolent leaking from rear of engine can not see from where. When I stopped the car the fluid kept coming out. Engine overheated, I checked the front hoses they are dry and no leak from the radiator. What...
You could have a leak coming from the intake or even the heads. Before digging into those difficult items, I'd check all of your freeze plugs for damage/wear/rust/leaks.
Jun 02, 2011 | 1996 Chevrolet Corsica
On a '96 GMC Sierra is there an air condition core or anything like that under the dash?
Yes,it is right next to the heater core,the dash has to be removed to replace it,it is the evaporator core,if this was helpful,please rate,thank you.
Jun 19, 2010 | 1996 GMC Sierra
Removal instructions for heater core
First disconnect steering knucke under dash. Remove dash assembly to reveal heater/AC case. Disconnect heater hoses from engine compartment. Discharge and capture AC refrigerant. Remove heater case ,replace heater core . re-assemble .
Apr 27, 2010 | 1998 Ford Taurus
Heater core replacement 1996 Ford Ranger
The heater core is on the passenger side of the dash.
You get everything in and out from under the dash.
Other than removing the cover you shouldn't have to remove anything else.
You should just have to remove 2-4 bolts that hold the plenum cover on, then undo the heater hose in the engine compartment, and I think two bolts along the bottom of the core and *** all drops loose.
The hard part is getting everything lined up when you put the new one back in.
Oct 31, 2009 | Apple iPhone Smartphone
My crown victoria is leaking radiator water inside the car. mainly on the passenger side beneath the glove compartment. It smells really bad, and I can't find the leak. Is there any way to get detailed...
Yes, it's the cars heater core leaking. The heater core is like a mini radiator under the dash-coolant circulates through it from the engine to provide the heat. To change the heater core is a very labor intensive job. You really need to get a repair manual, or go online to 'alldata' diy repair where you can sign up for 1 year or more access to your Crown Vics repair info. Excellent source for diagrams and instructions. I believe one year is $16.95, good for ONE car info for a year.
May 01, 2009 | 1996 Ford Crown Victoria
You do not have to do anything with the air conditioning, its all inside car under right side of dash. 1. go under hood and unhook heater hoses and bracket( if equiped) from core tubes. 2. go under dash right side remove 13mm bolt far right under dash thats so you can pull dash out a little ways to get cover off heater where heater core is.3. 1/4 in. socket set and 1/4 in. socket take screws out holding cover on look close there is one hidden top far right can't remember how maney 5 or 6 i think, screws all out use a little finess and remove cover and there will be your heater core. Good luck.
Apr 13, 2009 | 1995 GMC Jimmy
Water under dash board 1983 buick skylark
Your heater core needs to be replaced. The heater core is like a mini radiator, providing heat for the interior by coolant circulating from the engine, into the heater core, and back to the engine again. Like a radiator, a heater core can spring a leak, especially w/ age as a factor. This results in the leak inside the car, which also causes the 'smoke' you see, which is actually vapor form of coolant.
Nov 17, 2008 | 1983 Buick Skylark
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
