Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
The color on screen is not lining up. there are
The color on screen is not lining up. there is big blue line across screen.
  • Hitachi Master
  • 8,457 Answers
Ur convergence it dead.U know how to solders?Tries these websites for convergence kit.Tv repair World.com,Tvrepairkits.com.
Posted on Dec 12, 2009
SOURCE:
Colored lines across ipad screen
the screen needs to be replaced
Dec 20, 2012 | Apple Ipad I-pad
Toshiba 27A40 has single colored line across enter
Vertical output has cracked soldering. Around $150 to fix.
May 01, 2010 | Toshiba 32A33 32" TV
KP57WV700 - Blue Lines Across The Screen
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
The screen went black and now it has alot of lines across it
Sounds like a bad video card.A video inverter could cause distorted graphics but usually it turns out to be the graphics card.
Jul 30, 2009 | Computers & Internet
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
May 05, 2009 | Sony KDF-50E2000 50" HDTV
Red,green and blue lines across screen
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Mar 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Lines across screen
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
Mar 30, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Gateway fpd1960 tft lcd monitor has blotchy color lines across screen.
You likely have a bad 'controller' board, the one that converts the analog monitor signal into Row and Column addresses to tell the screen which pixels to light up, and which color. You may have a loose connection where ribbon cables connect to the board or the LCD panel, but you'd have to take it apart to see.
Likely the monitor part would be prohibitively expensive when you add in labor costs. If I owned it, I'd take it apart a bit and check for loose things...
tom
Nov 06, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
129 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
