Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing machine control locked
  • 8 more comments
  • Anonymous Jan 21, 2008
    the cycle is locked some where between pre wash and final rinse , the on\off button is flashing but will not start whin pressed. Even after switching the appliance off and on again I get the same result
  • Anonymous Feb 15, 2008
    I have the same problem. How do I unlock and finish the wash cycle.
  • Anonymous Mar 22, 2008
    wont start showing lock key
  • tekmom May 07, 2008
    "Control Locked" light is on. NOTHING works. Have unplugged several times to try to reset. Have pushed various buttons in various combinations...no luck. Help!
  • bkyserjr Jul 08, 2008
    ya same. Control lock what do i do?
  • Anonymous Jul 10, 2008
    I tried unplugging - I'm really frustrated with this washer. I have to slam the door shut in order for it to not beep incessantly and prevent my wash load from starting.
  • Anonymous Aug 06, 2008
    the control locked button keeps blinking and I can't start a load
  • mishell577 Sep 05, 2008
    locked control light on nothing works
  • Anonymous Sep 10, 2008
    Same problem as the others. Machine locks up for no apparent reason and have tried unplugging but to no avail. Tried to obtain a repair manual on this machine or even some advice from Maytag but can't find a web site for the co.
  • Sue Carroll
    Sue Carroll Sep 15, 2008
    washer is stuck on control lock will not do anything what do i do i tried to unplug it still noyhing .
What do i do
Posted on Sep 15, 2008
Simultaneously press the Option and Select buttons until the Control Lock light goes of.
Posted on Aug 10, 2008
A POSSIBLE SOLUTION TO THIS PROBLEM...
Try pressing the End Of Cycle Signal button for about 3-5 seconds until you hear a confirmation beep. That solved it for me as I brain-farted and thought that button only locked the signal level, and not ALL buttons/functions.
Posted on Jul 11, 2008
Press and hold the unlock button for several seconds. that will unlock it. However, mine still won't start in any mode.
Posted on May 10, 2008
6ya staff
SOURCE:
Hello,how do i unlock child lock from a hotpoint washing machine WDUD 9640 .I hold button mor times dosent work.switch off and on doset work I need a help please
Check page 6:
http://docs.hotpoint.eu/_doc/19509812000_GB.pdf
CHILD LOCK button:
to activate the control panel lock,
press and hold the button for approximately 2 seconds.
When the symbol CHILD LOCK is illuminated,
the control panel is locked.
This means it is possible to prevent wash
cycles from being modified accidentally,
especially where there are children in the home.
To deactivate the control panel lock,
Feb 04, 2018 | Hotpoint Washing Machines
Tip
Hoe to unlock the controls of whirlpool washing machine
  1. To unlock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light goes Off. To lock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light comes On.
on Aug 24, 2015 | Whirlpool Duet GHW9150P Front Load Washer
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Feb 09, 2011 | Washing Machines
My washing machine machine is saying control locked
To unlock the controls press and hold the "END OF CYCLE SIGNAL" for 3 seconds until the Control Locked status light turns off then release the button.
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Lid won't lock when going to wash.
Door Lock Failure
dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from
extending.
Machine/motor control detects open door lid switch when
attempting to lock.
Machine/motor control cannot determine if door
lid is in a locked state.
Door Unlock Failure F-83
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Control panel reads control locked
You problem have locked the control. There is a button on the front panel that says control lock. If you push adn hold this button for 3 secs the control locks or unlocks.
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you get control lock off whirlpool duet washing machine
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the machine is running and Control Locked light is on, the machine can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Unlock control lock in washing machine, whirlpool, duet
Hold control lock for 3 sec. It will make a sound and the door will unlock.
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
62 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
